Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th November 2008, 01:12 AM   #1
enzedone's Avatar
Default DIY PCB's
I found this excellent web site for making your own PCB's
Here is the information in a PDF format if anyone is interested
Sorry pdf was too large
Here's the site:
http://www.riccibitti.com/pcb/pcb.htm
It uses cheap paper from mailers instead of the expensive photo paper.
I have it in pdf if anyone wants it, but it's 3.2mb.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 20th November 2008, 01:24 AM   #2
MJL21193's Avatar
Been that, done there.
The photo paper recommended by Tom Gootee gives better results and is very available and pretty cheap.
Old 20th November 2008, 01:31 AM   #3
enzedone's Avatar
Default photo paper
I was going to use Glossy inkjet photo paper, but then saw this article
So you think that photo paper is still the way to go?
Old 20th November 2008, 01:35 AM   #4
Bonsai is offline Bonsai  Taiwan
wow - some great tricks.
I have never had any real success with making my own boards. I was lucky enough to work at an electronics company that used to do its own boards in-house (NTHP but double sided) and I befreinded the PCB dept manager. Over a period of 15 years, he made me dozens of boards for my personal projects ('PJ's').
For smaller boards, the techniques presented look easy - so I might give this a try again.
bonsai
http://www.hifisonix.com/
Old 20th November 2008, 01:55 AM   #5
cuibono is offline cuibono  United States
cuibono's Avatar
Over the period of a few years, I've gotten a good hold on using Eagle, and how to do pcb's from glossy photo paper. It takes a lot of patience and trial and error, but I highly recommend it. I wouldn't be able to do most of what I do without it. It allows for a lot more creativity..
Old 20th November 2008, 02:04 AM   #6
enzedone's Avatar
Default Play
O.k I will have to have a play with this photo method and see what happens
Old 20th November 2008, 03:24 AM   #7
GK is offline GK  Australia
That looks interesting but if you have a printer that does a good job on transparencies and enough ingenuity to knock up a UV light box, with off-the-shelf resist coated PCB laminate you can make boards for just about anything.
I’ve designed and etched thousands of prototype SMD boards this way over the years.
6 thou tracks are doable – really cr@ppy picture attached (sorry, no macro lens on phone) of 8 thou tracks to a quad flat pack with 19 thou lead spacing, which is still relatively easy to solder with the right bit.
Glen
Old 20th November 2008, 04:53 AM   #8
I agree. I have had excellent results with laser printed transparencies. I print the transparency twice to make sure I get a solid black, then expose the resist for 10 minutes under a desktop fluorescent lamp with a "true daylight" bulb. I use a sheet of glass from a picture frame to keep the transparency flat against the board.
Old 20th November 2008, 05:03 AM   #9
enzedone's Avatar
I would have no idea how to make one of these up. And it would only be worth while if your going to make a lot of boards.?
Does anyone have plans and/or a web page to show how to make one of these?
Old 20th November 2008, 05:09 AM   #10
Juergen Knoop's Avatar
UV light box?
I have 8W UV-A tubes lying around, please suggest box geometry and mounting height for best exposure!
regards
Page generated in 0.10689 seconds (79.02% PHP - 20.98% MySQL) with 10 queries
