Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th November 2008, 05:22 PM   #1
redrabbit's Avatar
Default gear with BCD in/outputs...advice
I bought a precision decade resistor, but it interfaces.communicates and operates via BCD (binary coded decimal).
I have no experience with digital signals, but I think this is one of the most basic systems.
I'd like to find a way to operate this decade resistor, because it is (should be) very accurate...to 0.01%. I can find NO info or manuals on the unit, nor what it might interface with.
Julie Research Labs RD 105 M
Photos:
Front
http://i5.photobucket.com/albums/y17...t/DSCN3556.jpg
Rear
http://i5.photobucket.com/albums/y17...t/DSCN3552.jpg
Inside
http://i5.photobucket.com/albums/y17...t/DSCN3549.jpg
Click on this pic to see what I know so far...
If I supply all the circuits with +5v (on back panel), I can hear the relay clicks, and I am able to use the thumbwheel to read ohms, but only within a limited range (10k ??)..."program button" must be out (disengaged). No power = no resistance on the banana terminals.
Any ideas?
=RR=
Old 20th November 2008, 06:38 PM   #2
redrabbit's Avatar
Should (can) this thread be moved into "Digital" ??
Worse-comes-to-worse, I could install a rotary switch for each decade , to activate the relays.
I count 10 relays connected to each card, with each card being a "decade" of resistance.)
=RR=
Old 21st November 2008, 02:35 AM   #3
redrabbit's Avatar
I figured out how to use it without the remote digital BCD signals.
( I don't really need the remote BCD functionality anyways)
Before, I mentioned I had achieved limited range using the front panel when powered with 5v.
Well, that was at 0.5 amps, and that current is not enough to trigger all the relays. At 1.3 amps, the front thumbwheel switch works the full range, and is working well now.
=RR=
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
I am looking for the following gear ....... musicprodusa Instruments and Amps 0 26th November 2006 08:22 AM
Gear to use SoundEasy rick57 Multi-Way 10 21st March 2005 11:55 AM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Page generated in 0.07521 seconds (74.06% PHP - 25.94% MySQL) with 10 queries
