Hook up wire? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd November 2008, 08:43 PM   #11
Renron is offline Renron  United States
Renron's Avatar
Damn it!
You made me go look it up in my NEC manual.......grrrrrrr......
HONEYWELL 22 AWG 4C (FTI) TYPF CM-CL2 SUN RES (ROHS)
22AWG is rated for 300v at 70*C
22AWG is rated for 5A max.
Type F (TYPF) is the temperature rating of 155C or 311F (PVC coated, PTFE is higher)
4C is 4 conductors
CM-CL2 is ComMunications - CLass 2 (General purpose not rated for risers or plenum use) (that means inside air ducts or where fumes could be inhaled if exposed to fire)
Sun Res means OK for exposed outdoor use (somewhat UV protected)
What else do you want to know????
Is it solid or stranded?
Is it sheilded?
I actualy enjoyed looking this up......I MUST be sick......
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 22nd November 2008, 08:47 PM   #12
Renron's Avatar
Originally posted by burnedfingers
Do the right thing and return it to him.
At least call and offer it....he may just give it to you. It's not worth that much..~$15
and it brings you good Karma too.
Ron
Old 23rd November 2008, 11:55 AM   #13
cjkpkg is offline cjkpkg  United States
If memory serves me right, ADT actually used a subcontractor for this because we were having one of the terminals moved...didnt sign anything and no card - all I remember is that his truck had something on the side of it...not ADT....
Heck...I'm glad the wife didnt clean the garage and just throw it away!!! at lest its getting put to a good use!!!
Thanks for all the info!!!
It is solid core wire...not shielded...
hook up wire Burnedfingers Parts 5 12th January 2009 06:34 AM
Hook-up Wire? mwh-eng Tubes / Valves 6 4th March 2004 07:30 AM
Hook Up Wire Suggestions? Tom D Parts 8 27th August 2003 04:03 PM
hook up wire question TubeHound Parts 2 18th November 2002 02:12 AM
Hook-up Wire Cambe Parts 0 2nd October 2002 04:58 PM
Copyright 1999-2017 diyAudio
