Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th November 2008, 09:52 AM   #1
Gunders is offline Gunders  Norway
Default Max voltage for single supply opamp
I have a simple question:
If I have an opamp intended for +-15 V and I want to use a single power supply rather than +- rails, what is the maximum voltage I can use? Is it 15 V or 30 V?
Old 19th November 2008, 09:58 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
30 V It's the voltage between V+ and V- Notice though common mode limits for the inputs. Some opamps can handle signals down to ground and some don't. Chck the parameter "common mode range" in the datasheet.
/Per-Anders (my first name) or P-A as my friends call me
Old 19th November 2008, 03:56 PM   #3
Thank you
Looking for some NS LME49710 Single DIP Opamp dtm1962 Swap Meet 0 4th September 2008 01:06 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
LM3875 using single supply voltage? SM7UYJ Chip Amps 3 21st December 2004 08:55 PM
Run opamp on single supply Ryssen Parts 1 15th March 2004 01:28 AM
Page generated in 0.43957 seconds (13.93% PHP - 86.07% MySQL) with 10 queries
