Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th November 2008, 10:29 PM   #1
Banned
Default Oversize PCB causes problems.
I have a projected requirement for 2 - 4 PCBs a month over 5 years - demand dependent. This will hopefully increase with expansions of the product lineup.
The problem is the dimensions - 32 x 9.5 inches. It's doublesided, but not otherwise demanding to produce.
I can easily find manufacturers for boards up to 24 inches, but above that things get difficult.
Does anybody know a supplier who can do this? International is not necessarily a problem, but price is critical, as always.
w
Old 18th November 2008, 12:16 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
www.pcbcart.com can make 600x700mm
Can't you divide your thing in two pieces? What is it, your project?
/Per-Anders (my first name) or P-A as my friends call me
Old 18th November 2008, 09:48 PM   #3
Banned
Hi P-A,
It's totally unrelated to audio, but I didn't think anybody'd mind, I was just in a thread about DC current sensing.
It's for a backlit AC/DC control panel for a yacht (millionaires plaything). It has a limited production run.
It carries in excess of 120 LEDs (and ballast resistors), the majority firing into a lightguide and all in the same circuit, the rest are status indicators. The lightguide and breakers are pierced in numerous places to accommodate some 30-odd breakers and switches.
I hand-fabricated (etched) 3 individual single sided boards for the prototype. They were pre-cut on a CNC router, but required to be hand-drilled. This works, but 2 x 25-way D-type connectors had to be broken out and hand-wired to individual headers for the status indicators and meters. I need to productionise it and get the manufacturing costs down.
The usable board real estate is limited but I can land the D-types on the board and fan them out if I use 2 mezzanine boards and go to doublesided, but the additional board-to-board connectors make this very difficult if the board is broken into 3 parts.
All I need (!) is to get this board made in one piece for the same price as it would cost in 3 pieces...
w
Old 19th November 2008, 04:51 AM   #4
peranders's Avatar
I'm sure you can solve this by joining two high quality pcb's together. The cost isn't per board, it's more per area.
If you must make a strong joint you can use a third board with cut up holes at the end so you'll get plated half circles at the edge of the board. This is a common method when you want to solder a board on top of an another.
B&K 700 problems? ThSpeakerDude88 Tubes / Valves 12 14th March 2009 04:59 PM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 02:26 AM
I have hum and DC-problems Progg70 Solid State 10 5th August 2007 05:01 AM
Problems with an amp jarolda Car Audio 28 16th August 2005 09:12 PM
Need to oversize trafo? PederBass Solid State 6 30th April 2004 12:16 AM
Page generated in 0.07355 seconds (81.48% PHP - 18.52% MySQL) with 10 queries
