Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd April 2003, 12:30 PM   #1
PhopsonNY's Avatar
Default JFETs for 5ma CCS?
Hi there,
Does anyone know what combination of Cascoded JFETS and resistor are needed to obtain a 5mA opamp Biasing into Class A.
I cannot seem to find out the exact JFET # to acheive this.
Thanks for all the help.
Cheers
Old 3rd April 2003, 01:13 PM   #2
SY's Avatar
Any JFETs with an idss of more than 5 ma will work. The exact resistor values will have to be determined experimentally for each FET pair, since idss can vary 5 to 1 for a given part number.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 4th April 2003, 03:47 PM   #3
A quick look through my 1968 data book (I got it for 50 cents!) gives a few possibilities for JFETs. Some of the items for 5-10 mA Idss are 2n3822, 2n4221, mfe2093-mfe2095, mfe4002, mfe4005, mpf104, mpf152, mpf155, mfe2000. For 10-20 mA Idss there are 2n4222, mfe4003, mfe4006, mpf105, mpf 153, mpf156, 2n3823, 2n4223, 2n4224, 2n4416, mfe2001, mfe2002, mpf102, mpf107. A lot of these may be hard to locate and many of them are in cans, but they did exist at one time.
With a 5mA target current, have you consedered using a CCS made of BJTs?
Old 4th April 2003, 07:33 PM   #4
Audiofanatic's Avatar
Hi Daniel Rosa,
Do you prefer a BJT to a Fet? And if yes, why?
Audiofanatic
Be nice to animals.
Old 4th April 2003, 07:56 PM   #5
Audiofanatic,
I use BJTs because that's what I have. If I were to try to keep a reasonable assortment of FETs I'd have to buy a second garage. As for the strengths and weaknesses, there's a a wide overlap where it may be difficult to choose one over the other. What BJTs offer are: easy availability in higher voltages; higher current ratings; for a given device a more independant dropout voltage with respect to current.
Old 4th April 2003, 09:48 PM   #6
diyAudio Retiree
Default Jfet current sources
http://www.vishay.com/docs/70596/70596.pdf
When cascoding I use resistor votage divider on gate of upper jfet to get 5 to 7 volts on bottom JFET for best Goss.
Old 20th December 2008, 05:58 AM   #7
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Jfet current sources
Good PDF with JFET current sources. Thanks
I see 2N4416 in list above.
Is it any good for preamplifiers?
Which one is better: 2N4416 or Fairchild PN4416 ... ???
lineup
Old 24th December 2008, 03:55 AM   #8
bear's Avatar
They used to make purpose made "diodes" specd that way... Siliconix used to make 'em... maybe Vishay has the line now...
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
SiC JFETS revintage Pass Labs 15 27th August 2009 02:43 PM
jfets for preamp kzeprf22 Solid State 14 21st November 2008 02:35 PM
F3 jfets needed coils Pass Labs 4 5th October 2007 08:23 PM
got a bag of 30 J201 JFETs, what can I do with them? bikehorn Solid State 2 2nd June 2007 01:18 AM
Matching Jfets NickC Solid State 10 7th December 2005 03:13 PM
Page generated in 0.09571 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
