Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th November 2008, 10:15 PM   #1
vonfilm is offline vonfilm  United States
Default Good Variac for DIY use ?
Would this be a good inexpensive Variac for DIY use?
http://webtronics.stores.yahoo.net/ensavat.html
Any other suggestions?
Old 13th November 2008, 11:55 AM   #2
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Sounds very cheap to me. Remember a Variac provides no isolation. Don't use a variac on SMPS's , a lot will not start correctly and may self destruct.
Alternatives, 100 watt bulb ?
Old 13th November 2008, 12:19 PM   #3
That's exactly what most people would want for their test bench, and the price seems very good. Too good? Remember that Variac was a trade name owned by General Radio Corp. (GenRad), though I don't know who owns it now, the unit shown is likely not a real "Variac". Powerstat is one other well known name.
They're all autotransformers with no isolation, so the caution above is something you should pay heed to. I power amps and things that have their own isolation transformer from my Variac at the bench. For SMPSs I have another plate that carries a Variac and a big isolation transformer. This serves a dual purpose. It gives me isolation for things that need it, plus I can switch the wires on the isolation transformer to get 120 or 240 VAC, as needed.
Note that the typical wiring for a Variac will allow a slight overvoltage, usually 130 VAC or a bit more, so don't just crank it up without checking the output.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 13th November 2008, 03:20 PM   #4
I am not sure what is meant by "isolation" My initial use would be to slowly power up a Chipamp.com 1875 Power Supply and amp which has its own toroidal transformer.
Old 13th November 2008, 04:12 PM   #5
Mooly's Avatar
It means the output is still 100% connected to the mains, not isolated like a transformer would be.
You don't need buy one just for running a chip amp up use a low wattage bulb in series with the mains -- perfect.
Old 14th November 2008, 09:26 PM   #6
Apex Jr is offline Apex Jr  United States
Vonfilm...
The link you posted are for the cheap China made variacs
they will not last... Like above mentioned if you really
feel you want a REAL variac there are only 3 name
brands:
General Radio, GenRad and Technipower (All the Same)
Superior Electric which is the name Powerstat
Staco
Steve @ Apex Jr.
Old 14th November 2008, 09:38 PM   #7
lineup is offline lineup  Sweden
lineup's Avatar
Steve
you forgot the Tufvassons
http://www.tufvassons.se/eng_start.asp
http://www.tufvassons.se/vridtransformatorer.asp
They are supplied in Europe by www.elfa.se
lineup
Old 14th November 2008, 10:19 PM   #8
Who is a good USA source for a quality Variac?
Old 14th November 2008, 11:03 PM   #9
To Lineup...
I have never heard of Tufvassons, and went to there website
and all they stock is 230V input and not good here in the
states..The ones I mentioned make the 230V versions too..
Pictures look fine but I suspect Vonfilm would want enclosed
type rather than building an enclosure.
To Vonfilm
I have some reconditioned units in stock. from the
manufacturers I mentioned above and can contact
me thru email at steve.apexjr@prodigy.net
for what your looking for and we can talk from there.
Steve @ Apex Jr.
Old 15th November 2008, 12:08 AM   #10
You know, an autotransformer doesn't have a fixed ratio, and it usually adjusts from 0 to 130%. That means that the voltage rating isn't terribly important. I think a 230VAC unit would work just fine at 120VAC, even better if it was designed for 50Hz- the better steel would be lower loss at 60Hz.
DIY Variac Tyimo Solid State 4 6th October 2007 11:18 AM
FS 10A variac woody Swap Meet 8 16th May 2007 04:38 AM
Variac ben goh Solid State 21 12th March 2007 06:42 PM
Using a variac. anders.a Parts 3 4th April 2006 07:12 PM
Variac? Scribble Pass Labs 16 29th July 2004 02:12 AM
Page generated in 0.09909 seconds (79.48% PHP - 20.52% MySQL) with 10 queries
