DIY balanced line converter with bassis
It appears the Marchand has blown off my order for a Bassis board and parts kit, oh well:rolleyes:
In light of that I'm here to ask for guidance on producing a couple different modules 1: A Sallen Key filter based LFE EQ unit with feature set of the Bassis with some extra features and adjust ability. I want selectable, adjustable, defeat-able 12/18 dB per octave HPF with adjustable Q. And balanced output that's robust enough to handle driving several amp inputs in the normal Pro amp daisy chained(parallel) configuration. 2: A high quality balanced line converter for use with AVR pre outs, I'd like to have some switch or jumper selectable gain options like unity, 3, &6 dB gain Ideally I'd like to do the modules in such a way that you could pack enough of them into a 1 RU(preferably) enclosure to handle an 8.2 AVR setup. The idea that comes to mind is a vertical oriented PCB with a RCA in on one side and an PCB mount XLR out on the reverse. TIA for taking the time to look this over :) Fire away :D |
Is this even the correct forum for preamp discussion?
If not, would a Moderator please move this into the correct spot
Thanks :) |
| All times are GMT. The time now is 03:54 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
