| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi All
i'm new here and a newbie in music fanatic repair so i have an old emu sp1200 and i sometimes here hiss from a couple of outs (it's al old 1987 sampler with 8 outs) i open and know the prob is a polystyrene 4700pf capacitors, it worls but sometimes it makes hiss i need a replacement, check for styroflex and it seems ok, but my question is: which voltage? the service manual doesn't say anything than 4700pF plas. and there's no info on the capacitors itself (4700H ASC) could u suggest me some good capacitors to make the change and which Volt do i need? i don't know maybe i can check with a multimeter and the machine on, but before i need some info... sorry for the ABC stupid question... tnx |
#2 |
Check the supply rail voltages. As long as the cap is rated for that or higher, you'll be fine.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
I'll bet any polystyrene cap you get will be more then enough voltage. They are usually 160v and up. Other wise i guess find the highest volt electrolytic on the board and maybe double it to be safe.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#4 |
#5 |
you ought to just replace all the lytics. you said it's from the 80's right? those film caps are a lot less likely to fail.
#6 |
i would like to replace the 2 caps i have prob...
i know it's that the prob cause it's a common sp1200 emu problem and every time i touch them with the hiss and the sampler on i can stop the hiss.... i already reflow the solder but i think it's the capacitors is going to dye.... |
| Polystyrene capacitor as coupling in output tube stages | aldovan | Tubes / Valves | 10 | 3rd March 2009 11:11 PM |
| Capacitor Replacement - HELP PLEASE! | SoundQuest | Solid State | 1 | 2nd April 2008 12:36 AM |
| Capacitor replacement question | spooney | Car Audio | 3 | 15th September 2007 07:23 PM |
| Polystyrene Capacitor 0.178uf | macka | Swap Meet | 0 | 9th October 2006 08:05 AM |
| Capacitor replacement | bulgin | Solid State | 11 | 2nd August 2006 09:08 PM |
| Page generated in 0.08040 seconds (76.05% PHP - 23.95% MySQL) with 10 queries |
