| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello forum, is there anybody able to help me source a quad op-amp for my faulty Rane active crossover. ? It uses a JRC device, namely a NJM2059D which unfortunately is now out of production.
There are many thousands still left available from component sourcing companies however the minimum order i can purchase is 50 and at 3-4 pounds each this far outweighs the value of the Rane unit. Wondered if anybody has 2 of these op-amps going spare that they could sell me ? Thanks folks, |
#2 |
Looks like DigiKey might have it. It says to call them, might be worth the call. Here is the link.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#3 |
Hi, Thanks for your reply, they can source it at Digi-key however i need to buy 50 of them !!
#4 |
NJM2059D is a standard quad op-amp whose specs are not particularly good. You can use another low-cost quad op-amp with better performance, like LM837.
I use to feel like the small child in The Emperor's New Clothes tale |
#5 |
Hi Eva, i am nervous of changing the op amp for LM as the components around NJM2059D amp are extremely close values and strange values too, ie 9.09k and 23.7k etc (see rane schematic on website)
I think if the LM has different gain etc this will alter things as the NJM2059D does input level as well as sub sonic filter and part of crossover circuit too. Don't realy know as i just get by doing basic repairs using multimeter and simple tests on my own audio gear. Utsource.com will post worldwwide and have original parts, anybody sourced from them before ? |
#6 |
Proud Union Member
Does the schematic specify 1% resistors? I find it hard to believe they do. We have a lot of Rane gear at work and I wouldn't exactly call it "high-end" or "esoteric". It's often referred to as "Rain" as in "It sounds like Rain" as that's what the noise floor sounds like in much of it.
#7 |
Yeah it is noisy compared to what i use for my own rig, i have XTA DP226 on FOH and DP224 on Martin monitors, this Rane unit is a freind's who asked me to look at it for him.
Basically there is more output from one channel than the other, both lo and hi outputs on channel 1 are lower than on channel 2 with equal pink noise input to both channels. Passives are ok so i presume only input op amp left to eliminate. Outputs from both channels are not distorted with program music played through unit. Any thoughts other forum users ? |
| Rane Crossover Modification | kbasaran | Parts | 7 | 18th September 2008 02:01 PM |
| RANE RPM 26z digital crossover | batdorf9 | Swap Meet | 3 | 18th April 2007 02:22 AM |
| For Sale: Rane AC-22 Active Crossover | herm | Swap Meet | 2 | 1st June 2006 04:54 AM |
| Two different version rane AC23 crossover | ostie01 | Solid State | 0 | 18th January 2006 12:20 AM |
| Rane MX22 Electronic Crossover 4 Sale | Bill Fitzpatrick | Swap Meet | 0 | 28th August 2002 01:42 AM |
| Page generated in 0.09038 seconds (75.13% PHP - 24.87% MySQL) with 10 queries |
