| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
or equations will do.
My goal is to come up with some passive pllxo circuits for a 4th order Linkwitz-Riley filter. I'd like to experiment with some different values before committing to a more permanent solution. Any help is appreciated. Dan |
#2 |
Did it Himself
4th-order passive is almost impossible due to the impedance issue. Also you can't do Linkwitz-Riley with 4th-order, the Q will be 0.25 which is very droopy and probably quite poor for audio. You can only get Linkwitz-Riley in 2nd-order if you go passive, even that is difficult and would need a buffer and driver.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
There is some good info at the below link, no calculator though.....
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 | |
#5 | |
Yes you can. In fact the 4th order version is by far the original "famous" version, (It is two cascaded or squared 2nd order Butterworth filters) the 2nd order version becoming more popular and much abused later, 2nd order electrical L/R is not L/R acoustic nearly always. There is a L/R alignment for all even (2nd, 4th, 6th, 8th etc.) orders. http://www.linkwitzlab.com/filters.htm See http://www.linkwitzlab.com/proto.htm for PLLXO examples. without inductors you are limited to low Q second order. |
#6 | |
First order is very tolerant of component values. Second order requires some accuracy to achieve the desired roll off. Third order requires much greater component value accuracy.
regards Andrew T. |
#7 |
Unfortunately, the linkwitz lab link only shows the topic for active crossovers. I am looking for passive and line level.
#8 |
Just recently I was looking into PLLXO's, and concluded that for a complex and/or higher order, one would have to go active. Input and output impedance, and insertion loss are the big problems here.
double complete rainbow all the way!! |
#9 | |
This may be useful : http://focus.ti.com/docs/toolsw/fold...t/tina-ti.html |
#10 |
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
| Convert Line Level to Electric Guitar Level | miallen | Solid State | 4 | 16th May 2010 01:22 PM |
| inductor wire gauge for line level xover? | poldus | Parts | 0 | 2nd October 2007 04:06 PM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 04:13 PM |
| Page generated in 0.09561 seconds (88.70% PHP - 11.30% MySQL) with 10 queries |
