Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th November 2008, 09:50 PM   #1
glt is offline glt  United States
Default Nichicon KG "loopsided"
I have two Nichicon GK 10,000 uf 63V and they are heavier on one side (If you roll them they end up in the same position). One of them if I shake it it seems the innards are loose. Any idea?
Thanks.
Old 5th November 2008, 10:13 PM   #2
theAnonymous1's Avatar
Have you tested them at all?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 5th November 2008, 10:20 PM   #3
Hey, at least it's a Rubycon inside that thing.
Old 5th November 2008, 10:21 PM   #4
Is that for real?
Not tested them. Don't have a DMM that can measure capacitance...
Old 6th November 2008, 04:55 AM   #5
amc184 is offline amc184  New Zealand
amc184's Avatar
I wouldn't worry too much. I had a look, and pretty much every large cap that I have has at least a slightly uneven weight distribution, most of which I am sure are genuine and trouble free.
Did you get these from audiotek on eBay perchance? I bought a pair of 10 000uF 63v Nichicon KG Goldtunes from there a few weeks ago for a good price.
Old 6th November 2008, 06:25 AM   #6
Yeah, got it from Audiotek as part of the FET discrete power supply.
Lacking a capacitance meter, I calculated the RC time constant for the capacitor while discharging through a 5K resistor after charging it to 57V, and indeed the capacitance is 10,000 uF (in fact it "measured" about 11,000 uF)
Thanks for sharing.
Old 6th November 2008, 01:50 PM   #7
Send a message via MSN to jomatecc Send a message via Yahoo to jomatecc
Theyre fine If you got them from Audiotek, I bought 6 pair of 4700uf 100v Nichicon KG same dimension as the 10,000uf 63v and they are weighted on one side as well, works great though and sounds even better.
Music: Please audition with your ears not your eyes.
Old 6th November 2008, 06:38 PM   #8
amc184's Avatar
Yeah, I also chucked mine in an amp, no problems for me either.
Old 9th November 2008, 05:11 PM   #9
impsick is offline impsick  United States
impsick's Avatar
I wouldn't worry about the KG's but if they are GK's like you said then worry!
I always wondered how legit that picture was till i came across this myself...
Click the image to open in full size.Click the image to open in full size.
I dont know i thought it was a bit much.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 10th November 2008, 03:50 AM   #10
The temptation to cut open one of mine open is almost too much.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 05:53 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 01:09 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.09979 seconds (75.21% PHP - 24.79% MySQL) with 11 queries
