Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd November 2008, 12:12 PM   #1
RedCrow is offline RedCrow  United States
Default Need Schematics For ADCOM GFA-5802
Does anyone know where I can find the schematics for ADCOM GFA-5802?
Secondly are these two transistors inter ahngeable, IRF610 & 2SC4793?
I'll greatly appreciate any help.
Old 3rd November 2008, 07:01 PM   #2
Send a message via MSN to jomatecc Send a message via Yahoo to jomatecc
Default Here it is
Heres a link sign up and thats it. http://www.hifiengine.com/manuals/adcom/gfa-5802.shtml
Music: Please audition with your ears not your eyes.
Old 3rd November 2008, 07:29 PM   #3
since I havent reviewed the schematic for the 5802 i cant tell you for sure but 2sc4793 is a BJT while IRF610 is a mosfet device, they have very different characteristics although they can be used for the same purposes their implementation is usually different and not directly interchangeable.
regards.
datasheet here. http://www.toshiba.com/taec/componen...nc/66/7846.pdf
Old 4th November 2008, 07:00 PM   #4
Thanx for the reply, I did download the schematics from www.hifiengine.com but could hardly make out the labeling of parts since they're not clear and was hopeing to find a clearer layout elsewhere that's why I posted the request.
Concerning the interchangeability between IRF610 & 2SC4793 transistors, I just finished repairing an ADCOM GFP-750 in which I had to replace a bad 2SC4793 and the proiblem was resolved. With a second GFP-750 though, an IRF610 was used instead of the 2SC4793 as in the first one. All other component values and circuit layout seemed the same. Except where there was 2SC4793 in the previous one the second has IRF610 instead.
I've a lot of 2SC4793 left overs from the lot I ordered from DIGIKey and was thinking of using them instead of ordering the IRF610. Any suggestions?
Old 5th November 2008, 10:26 PM   #5
Hi Redcrow It depends on where you are using it, my thougth is if it worked for Adcom there is a good chance it will work in your circumstance, Id like to tell you to go for it but its really your call.
Im still trying to source a better schematic and more info.
regards
Old 5th November 2008, 10:39 PM   #6
I just looked carefully on the GFA-5802 schematic and it looks like they really designed the circuit with mosfet technology in mind, I don't know about this one Redcrow there is a lot of mosfet to risk. Id go with the 610 just to make sure.
Old 6th November 2008, 10:17 PM   #7
Thanks Very much, I'm going to stick with The IRF610, seems Adcom switched components along the way in their various GFP-750 designs. The schematics I have for the 750 listed 2SC4793 instead of IRF610. but for the fact that the 610 is printed on the board makes it less a case of mis-match.
Again thanx for the reply.
Request for Adcom GFA-555 MkII schematics trluser Solid State 7 31st December 2010 05:12 AM
DIT amp schematics ADCOM GFA585 rebuild? vincent_brient Solid State 7 20th December 2010 08:49 AM
BOSE Schematics DENSO Schematics packer Car Audio 6 25th June 2007 10:55 AM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
Schematics on the Adcom GFA-5802 K-amps Solid State 5 5th January 2004 11:56 AM
Page generated in 0.09436 seconds (73.91% PHP - 26.09% MySQL) with 10 queries
