Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd November 2008, 08:24 PM   #1
Default tape head amplifier
Hi!
I have an old reel-to-reel home recorder (late 60s).
I would like to record some tapes to PC maintaining the highest quality.
Since it has valve amplifier, I think the best way to get the signal is right at head output before any kind of signal amplification.
The question is: can I do a good tape head amplifier using only an opamp? If yes, how?
I would not like to buy a tape head amplifier IC until necessary.
Old 4th November 2008, 12:48 PM   #2
burbeck is offline burbeck  United Kingdom
hi David,
it is possible to construct a tape head pre amp, however this is not a straight foward job, the pre amp has to have tape EQ compensation and there are a few different specifications for this.
this along with the low noise and small signals involved make it quite a job.
how is the sound of the machine you have?
regards
bob
Old 4th November 2008, 12:53 PM   #3
Thanks, but I would do EQ with software... so I only need to know hot to hook it to a pc soundcard!
Old 4th November 2008, 02:29 PM   #4
Frank Berry's Avatar
You'll need a wide bandwidth chip which can also provide high gain. You might want to try a chip which is often used for video ... perhaps something like an AD847JN.
Frank
Old 4th November 2008, 03:20 PM   #5
Why do I need a wideband opamp? for amplifying bias frequency? sounds weird...
Old 4th November 2008, 04:25 PM   #6
oshifis is offline oshifis  Hungary
I doubt if it is possible to build a better sounding (not better specs) playback amplifier than the original valve amp. What is the problem with it? The only one I can imagine is hum and it can be cured.
Old 4th November 2008, 04:38 PM   #7
tkwou is offline tkwou  Canada
A tape head amplifier is very similar to a phono preamp. It just uses a different equalization curve. They use to be very common at one point. Even the old Dynaco PAS3 had one. The equalization can be done passively or actively like RIAA in a phono preamp. Below are a couple articles about building them.
http://www.bottlehead.com/et/adobesp...headpreamp.htm
http://www.stiftsbogtrykkeriet.dk/~mcs/index.html
Old 11th November 2008, 01:59 PM   #8
Wideband so you can gets lots of gain from a single chip and not attenuate the highest audio frequencies.
Frank
Nakamichi dr-2 3 head tape deck tyler477 Swap Meet 0 29th November 2008 03:54 AM
WTB: Tape head demagnetizer in Australia rabbitz Swap Meet 3 16th January 2008 10:28 AM
AKAI GXC-39D Tape Deck head advice gmphadte Solid State 19 24th October 2007 02:24 PM
tape head sudden magnetization, help please federico moreno Analogue Source 13 14th June 2006 06:31 PM
Page generated in 0.08426 seconds (78.33% PHP - 21.67% MySQL) with 10 queries
