Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st October 2008, 03:02 PM   #1
Default Solder Mask pattern question
I have a couple PCB's for a Pass pre-amp I bought several years ago off a fellow in Croatia along with a parts list. I sourced the components a while ago and I now have time to assemble the boards.
My question is: I have 4 zenner diodes to drop in. I know the polarity of the diodes, but on the circuit board there are no polarity markings like a + or -. For each diode there is a round through hole and a square through hole. Going off the round vs square through holes, is there a way to tell what the polarity should be on the board?
Thanks,
pat
Old 2nd November 2008, 06:38 PM   #2
BrianL is offline BrianL  United States
Generally the square pad is the cathode -- i.e., it matches the end of the diode with the stripe.
bel
Old 2nd November 2008, 08:50 PM   #3
Thanks.
DIY solder mask Magura Parts 65 19th January 2012 04:26 PM
peelable solder mask merlin2069er Parts 1 14th May 2009 09:16 AM
Solder mask josefr Solid State 6 12th May 2003 07:17 PM
Solder mask vpharris Parts 1 28th March 2003 02:42 PM
solder mask bwoca Parts 3 18th April 2001 01:38 AM
Page generated in 0.05926 seconds (69.35% PHP - 30.65% MySQL) with 10 queries
