Heatsink effieciency - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st April 2003, 06:49 PM   #1
Matttcattt's Avatar
Default Heatsink effieciency
what is the effieciency of a heatsink measured in? is it the degrees C that the temperature rises per watt of power?
how do i work out the effieciency of a heatsink? i will post a pic of some heatsinks i found in a skip.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 1st April 2003, 07:30 PM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
1. Yes C/W
2. You can apply a known amount of Watts on it and measure the temp rise Then you get the C/W number
Mads K
Old 1st April 2003, 07:50 PM   #3
Matttcattt's Avatar
how could i do that? with a big resistor? like a 20 watt one, and put volts through it?
Old 2nd April 2003, 02:43 AM   #4
Default Thermal resistance
You will preferably need a metal encased resistor that can be efficiently clamped to the heat sink. Then you will need a voltage souce or just stepped down ac from the mains. You should pick some convenient current , say 1 Amp. Then with a 12 volt step down transformer , the resistor would be 12/1 = 12 ohms. You can pick anything close to that. This would give you (in this case)12x1=12watts. Measure the temperature rise after say 30 minutes and then divide by the wattage. Note that you must measure voltage and current in your setup.
Note that the heat sink must be oriented the way you intend to use it.
Fantastic
Old 2nd April 2003, 03:20 AM   #5
Brian Donaldson's Avatar
Here's a pic of my test setup. I used 4 50W 150ohm resistors in parallel. Measure the resistance and voltage and compute wattage. I bought a thermometer and packed it in between fins with a paper towel tohold in contact with aluminum. Also use heat sink grease to insure the heat is transmitted to the sink and try to test in the same temp/watt range you hope to use the sink in.
Heatsink... Lewis Moon Chip Amps 8 26th November 2008 07:22 PM
One heatsink for each mos ? pa Pass Labs 3 1st April 2002 10:29 PM
Copyright 1999-2017 diyAudio
