mystery part: upd 6360c - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st April 2003, 06:59 AM   #1
sangram is offline sangram  India
Default mystery part: upd 6360c
Hi
I'm looking for any info on this part. I have managed to locate some price lists, but I'm not sure what the chip is used for.
It comes out of a graphic equaliser, a pdip package, and at first blush seems like a buffer amp. I've not seen this thing myself yet, it's quite a way away and I needed to figure if anybody had any info on the part before I got into the guts of it...
Old 1st April 2003, 09:01 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
The upd6360c is used in the NAD5300.
If someone here has a schematic of the NAD, this could help you.
/Hugo
Old 1st April 2003, 03:38 PM   #3
Thanks netlist
Any idea as to which section it is used for? Analog output buffer, brickwall filter?
It is beginning to sound more and more like an opamp, but any clue on what configuration (single, dual, quad?) and whether it is swappable with any more common chip?
Old 1st April 2003, 04:10 PM   #4
Netlist's Avatar
Absolutely no idea; you'll have to wait till someone comes up with
more information or a schematic. Maybe you can post some more info about your EQ? Brand, type..
/Hugo
Old 1st April 2003, 04:26 PM   #5
UrSv is offline UrSv  Sweden
UrSv's Avatar
Default Re: mystery part: upd 6360c
Hi
I think UPD is usually a NEC part and the UPD63xx series is 4-bit microcontrollers used for IR remote control functions. Can't find UPD6360C though, maybe it's custom although used in Hitachi TVs also?
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 2nd April 2003, 05:46 AM   #6
Default Re: Re: mystery part: upd 6360c
Originally posted by Netlist
...Maybe you can post some more info about your EQ? Brand, type..
The Equaliser is a 10 band per channel Technics equaliser, SH-E4, part of a compact component boom box that actually sounds pretty good. Doesn't have a CD input. awfully old.
Probably custom, but maybe you're right. The technics has a bus control system which involves little plugs sticking out at the top an bottom of each piece, which transmit power, signal and control info - no wires needed between components, and each component is also connectable with normal RCA plugs - neat. The microcontroller may be being used for switching inputs, EQ in and out, etc?
Old 2nd April 2003, 05:15 PM   #7
Pjotr's Avatar
http://www.necel.com/nesdis/image/X10088EJ5V0SG00.pdf
Not exactly what you are looking for. Maybe it helps. But many numbers of NEC are not on the internet. If you call NEC they are sometimes helpful to provide a paper datasheet.
Cheers
little 6.5 mystery ... oface Full Range 6 5th November 2007 12:20 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 06:45 AM
part# for spare part for CDM-1 wanted joe Digital Source 5 20th March 2007 08:59 AM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 02:29 AM
mystery... mista2 Multi-Way 1 14th January 2005 05:20 AM
Copyright 1999-2017 diyAudio
