| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
lsk 170c jFETs are testing out at 10mA to 30mA. I've got about 40 between 20mA and 30mA Idss. What would these be best used for? Can I find the Yfs easily to see if they are close to a 2sk369v? Any thoughts?
regards Andrew T. |
#2 |
Hi Andrew,
That question got me thinking, does this help http://books.google.co.uk/books?id=0...esult#PPA35,M1 |
#3 |
here is datasheet from manufacturer www.linearsystems.com
http://www.linearsystems.com/datasheets/LSK170.pdf
lineup |
#4 |
lineup |
#5 |
thanks,
Mooly, can the Yfs test measurement be done at DC? instead of at RF? When testing Idss, the Vgs =0V and Vds=10V with RL=100r. Then Yfs=infinity, which is plainly ridiculous.
regards Andrew T. |
#6 | |
http://www.borbelyaudio.com/adobe/ae599bor.pdf |
#7 |
Andrew, this is something I have never measured. I don't know is the honest answer ! I suspect there is no one correct answer in that the result depends on the particular application, and that application depends on the correct choice of FET. Sort of chicken and egg thing. Sorry.
#8 |
For a given technology, there is a direct correlation between gfs, Idss and Vgs off. Here is an example taken from the BF256 datasheet. It's just a matter of finding the right parameters to put into the equation of the device. It can probably be found on the web. Otherwise, you can measure gfs at low frequencies; a static, DC measurment makes no sense however. |
#9 | |
If mhos is the inverse of ohms then R=V/I becomes Mho=I/V or if the curve is not straight then Mho=deltaI/deltaV. However Borbely states Mho=2*Idss/Pinch off voltage. Why is there a factor of 2 times in Borbely's formula? and if Borbely is close to right and both terms in the formula are DC derived, then why is Yfs @ DC a nonsense?
regards Andrew T. |
#10 | |
gm = d I (d)/ d V (gs) so when you differentiate, the 2 goes on the outside. |
| SiC JFETS | revintage | Pass Labs | 15 | 27th August 2009 02:43 PM |
| JFETs for 5ma CCS? | PhopsonNY | Parts | 7 | 24th December 2008 03:55 AM |
| FS: Idss matched K170 | bbp | Swap Meet | 1 | 26th August 2007 07:25 PM |
| Spice: how to set IDSS etc? | bear | Solid State | 11 | 12th August 2005 02:20 PM |
| Ono - 2SK170, Which Idss? | transducer | Pass Labs | 11 | 25th March 2003 10:29 PM |
| Page generated in 0.10573 seconds (79.55% PHP - 20.45% MySQL) with 11 queries |
