Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th November 2008, 06:11 PM   #31
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
I am certainly not one to advise, but this is the one I am using,
http://www.microchip.com/stellent/id...cName=en023805
PICkit2 Programmer, starter kit.
I had to start somewhere. Visit www.microchip.com
Old 25th November 2008, 06:49 PM   #32
justblair's Avatar
For PIC's have you had a look at JAL?
I have played with it a little, it's open source software and it's editor will compile to your programmer
http://www.voti.nl/jal/index_1.html
This is a good book to get you started.
It's basicly a pascal based programming language. There are includes published for the most commonly used harware that you can patch in to your program and save you time. Ie if you want to use a display, you can write "include HD4780" and all the code from the include file will be compiled. You can write simple programs in very few lines.
I have not sat down with it for a while, other projects sort of took over, but i liked the easy to read language and the open source nature of the package.
Old 25th November 2008, 06:49 PM   #33
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Mooly, you can also use MPLAB IDE with the PICkit 2 programmer. That is a development environment which allows you to write code, compile, and program the micro all from one piece of software.
Brian
Old 25th November 2008, 06:59 PM   #34
Mooly's Avatar
Hi Brian,
Have the full MPLAB IDE suite installed.
That is what I used to get my LED to light.
Used the 16F690 MPASM files + "Linker" files and object code I think ? It worked and programmed direct to PK2 from MPLAB. It finds the PK2 and seems to know what to do.
Hi justblair,
I have been surrounded by library books. An Elektor PIC book recommends JAL. With the PK2 starter kit coming with all the software I went with MPLAB. There a good forum on the Microchip site too.
Old 25th November 2008, 07:03 PM   #35
justblair's Avatar
The book that I referred to is published by elector, it may be the same one.
JAL is free to download, so it might be worth trying out for an evening.
I looked at MPlab, but it is a low level programming language, and it just bamboozled me. I found JAL to be better. I also tried out C++ as well, JAL was a little easier to digest.
Old 30th November 2008, 05:35 PM   #36
Mooly's Avatar
I knew this wasn't going to be easy.
I had no idea it was going to be this difficult though
So much knowledge seems to be assumed.
I have got an LED to flash though with the help ?? -- erm, if that's the word -- of the tutorials. Over two weeks to get an LED to flash
Old 30th November 2008, 07:41 PM   #37
Hi Mooly. What exactly are you trying to get the pic to do?
Brian
Old 1st December 2008, 07:24 AM   #38
Mooly's Avatar
Hi Brian,
Two things really. First, it's something that I feel if I don't try and get into now I never will. I am hoping that that point will come where things start to click into place.
Ultimately it would be nice to be able to use PIC's in various projects. Remote control etc. The electronics involved holds no fears, but this !!!
So something like,
http://home1.stofanet.dk/hvaba/fprc5rx/index.html
although this uses a PIC not directly supported by PK2
PIC PROGRAMMER Junebug/PicKit2 clone/GTP USB ?? Paswa Digital Source 0 4th August 2008 04:16 AM
C Programming problem FuriousD The Lounge 1 1st December 2005 10:38 PM
PIC programming serosmaness Digital Source 12 6th February 2005 11:33 PM
PIC programming future Parts 33 4th June 2003 05:26 AM
Page generated in 0.10388 seconds (75.84% PHP - 24.16% MySQL) with 11 queries
