| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
My CDP uses M5238 op amps in the I/V stage. Before replacing
them I would at least want to know what they actually are, but I have failed to find data sheets for them. I know the pinout and they seem to be low-noise JFET input, probably manufactured by Mitsubishi (but they seem not to make op amps ).I have also found a cross-reference table which suggest they may be equivalent to NJM2082, for which I have data sheets. Can somebody fill in with more data about these op amps, or even supply (a link to) the data sheet? Thanks in advance |
#2 |
diyAudio Moderator Emeritus
Only found this link:
http://www.geocities.com/SiliconVall....htm#Tigabelas I know them and replacing them by another Fet input type like OPA2604 / OP275 / OPA2134 will be better for your ears. Jean-Paul
It's only audio |
#3 |
Thanks Jean-Paul,
that at least seconds the info that it is equivalent to NJM2082. The low-noise claim I found somewhere seems not quite correct then. Anyway, OPA2134 and OPA2604 are the ones I intended to try for a start. I don't really know what parameters may be most important for I/V-conversion? BTW, it was listed as a Mitsubishi IC in your ref. too. Yet when checking the web pages of Mitsubishi Semiconductors, they seem not to make any op amps at all. Strange. |
#4 |
#5 |
Thanks Netlist.
I am afraid i already had the info you provided, however. I think I did say I have the NJM2082 data sheet. I don't know how close equivalents the two circuits are, though. |
#6 |
For I/V I would use the fastest opamp I could find if it has to be an opamp. Maybe LM6172 will do at this spot ? It is bipolar though but offset is relative low.
It's only audio |
| Tube manaul data sheets | atmars | Tubes / Valves | 3 | 1st February 2009 10:46 PM |
| data sheets for 7239 and 8068 | nhuwar | Tubes / Valves | 3 | 20th May 2008 09:05 PM |
| Where to find data sheets? | Zap | Tubes / Valves | 4 | 20th November 2007 06:38 PM |
| Data sheets for japanese transistors? | Cradle22 | Parts | 2 | 8th September 2003 11:22 AM |
| Japanese data sheets | HarryHaller | Solid State | 1 | 16th May 2002 06:54 AM |
| Page generated in 0.07435 seconds (81.79% PHP - 18.21% MySQL) with 11 queries |
