Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
2sk135  2sj50
2sk135  2sj50
Old 27th December 2003, 03:13 AM   #31
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
All TO3 have magnetic leads.
Isn't that to worry about if one goes for the nonmagnetic resistors everywhere ?
Old 27th December 2003, 10:25 AM   #32
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
well,
you'll have to solder the nonmagnetic resistors instead of just letting the leads attract eachother
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 28th December 2003, 05:53 AM   #33
universum is offline universum  Netherlands
universum's Avatar
Lightbulb Densen
plasma fire
Well i guesss it is:-((
But then there's the Densen-cd,it will demagnitize your whole system,and youre worries will go away once you heard the differance between you're old system against the new cleaned one....do you see the light?
Vision is the Art of seeing things invisable.
Old 31st December 2003, 03:34 AM   #34
KBK is offline KBK  Canada
Default New Equivalents!
I belive the company EXICON is now manufacturing/ selling exact replacements for the Hitachi J49.....J56/K134....K176 MOS-FET series. Finally back in print again!
I'm of the cliff without a bicycle here.. I had the bad sense to buy a mint Counterpoint SA-220 amplifier (about $500cdn!! couldn't resist!!), but.. it has the IRF 9241/RF M10N15 FET tranistors in it.
Apparently there is no replacement............
Does anyone know about these puppies?
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 29th July 2010, 06:19 PM   #35
KJ2005 is offline KJ2005
Default Old amplifier built around 1981-82
Originally Posted by peranders View Post
Lot's of guys here (including myself) have built amps with K135/J50 so if you want some input ask.
Hi Per,
I know it's a long time ago, but try to ask you anyway.
Working with valves one old amplifier with SJ50/SK135 turns up in the memory all the time. I have bought 8 pairs of mentioned Hitachi's mosfets. I attach a copy of the old circuit - it sounds very good and I just want to hear your opinion of the schematic.
Kim, Denmark
Old 29th July 2010, 06:41 PM   #36
Mooly's Avatar
2sk135  2sj50
It looks to be a variation of the old Hitachi application notes... there were many offerings at the time and kits too.
I'm a huge fan of Laterals
If you like the musical sound many good valve amps produce then have a look at this one of mine as well,
http://www.diyaudio.com/forums/solid...ned-music.html
Here's the Hitachi variation as an old Maplin kit... this had a real following at the time.
Old 1st August 2010, 09:05 AM   #37
I have looked at the schematic of your mosfet amp. Looks good and symmetrical to me - with rails of +-45Vdc and servo feedback - I am not audio engineer.
My friend is and he claims that: 1. power fets should be driven with stronger drivers than expected. 2 He do not like power fets because of the different act of N and P fets.
I say : I like like the mid-and highrange sound better from mosfets than bipolar, but would like to have a little better attack in the low frequence area.
I have tried with +-45Vdc on the attached schematic of mine but I reached better control of the 12" woofer with +-70Vdc on the double pair Hitachi 2SJ50/2SK135.
I have found ( for me) the best sound in midrange and highrange in L58A with the sj44/sk163 but lack of control because of only one pair 34/149 powerfets.
The intention is to make the Luxman drivercurcuit with a doublepair powerfets. It is hard to find the sj44/sk163 today.
I think that the BF760/BF757 in my circuit drives the powerfets very good - one might find better drivers today than the old Motorola types.
rgds.
Old 1st August 2010, 09:30 AM   #38
Default 2sk227/2sj83
Originally Posted by megajocke View Post
Does anyone know anything more about these transistors? They seem to be similar to 2SK135/2SJ50. I can't find any datasheets.
2SK227: 160V, 7A, 100W
2SJ83: 160V, 7A, 100W
7 years too late!!
The mentioned powerfets from Hitachi was used in 1981-1983 by a danish company in a 100w mosfet amplifier. Compared to 2SJ50/2SK135 they messured better in the same aplication - Hitachi told them to be identical to 50/135 but we could not get any datasheets from the factory at that time!
I have 3 pdf. files with specs for 2SK227/2SJ83.
rgds.
Old 1st August 2010, 02:22 PM   #39
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
The soundcraftsmen amps use the K135/J50 pairs and they are still a fav. not the best i have heard but there is something about them that is very listenable.
Old 2nd August 2010, 08:20 AM   #40
Have never heard "The Soundcraftsmen" mosfet amplifier. I have ones tried with the Borberly drivercircuit without luck and buz900/905. I do have in mind that the buzīs did not sound like the original Hitachi's - might be wrong on this one.( have bought 16 pcs of the original)
Still find the erlier attached circuit as one of the better mosfet amplifers. Is it possible to attach the Soundcraftmen schematic?
Rgds.
2sk135  2sj50Hide this!Advertise here!
Nos Hitachi (20) 2sj50 (20) 2sk135 ashbytub Swap Meet 4 21st March 2012 04:34 PM
2sk135 2sj50 matching muizel Parts 24 13th March 2011 05:26 PM
sub for 2sj50/2sk135 sasha Solid State 20 27th March 2008 03:28 PM
2sj50/2sk135 jean-paul Swap Meet 0 26th February 2006 09:16 PM
I need 2sk135 and 2sj50 DJG Swap Meet 32 7th February 2006 09:03 PM
