| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am building two power supplies:
12V transformer >> schottky bridge followed by RC >> -5V discrete regulator >> preamp 115V 50VA trans (.435A) >> schottky bridge followed by RC >> 70V discrete reg >> preamp I want to insert Haggerman's RC snubber network across the secondaries *before* the schottky bridge. I have Mills MRA-5 resistors (5 watt, 200V rating) and MRA-12 resistors (12 watt, 400V rating). For the caps, I have the 715P series orange drops rated at 600V and 1600V. I would like to use the smaller mills and orange drops on both the -5V and 70V supplies if possible. Is this doable or must I use the larger mills and orange drops on the 70V supply?
Cheers ~ Mike |
#2 |
Your voltage and power ratings are OK but your choice of resistor is not. Even so called low inductance wirewound resistors are not particularly low inductance in low values particularly, I suggest you use either Metal oxide or carbon resistors in this application. Regards, Rob. |
#3 |
Thank you Robert! In trying to discover the answer to my question myself, I reread Jim Haggerman's whitepaper on snubbers, and I noted that he recommended carbon comp resistors. I will pick some up. Thanks again.
Cheers ~ Mike |
| voltage rating for Ci? | rfenergy | Chip Amps | 10 | 21st June 2008 09:24 AM |
| Generic snubber values: fixed-/variable-voltage regs | hollowman | Power Supplies | 44 | 28th April 2008 10:09 PM |
| Using a cap above its voltage rating? | h_a | Parts | 10 | 6th October 2007 03:46 PM |
| Zobel cap voltage rating | Khron | Multi-Way | 20 | 25th August 2007 04:45 PM |
| Choke-Input: How do I calculate the right snubber for high-current-low-voltage | Blitz | Solid State | 20 | 24th March 2004 08:37 PM |
| Page generated in 0.05509 seconds (79.29% PHP - 20.71% MySQL) with 10 queries |
