Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th October 2008, 06:17 AM   #1
Default SMD diode ID please
Can anyone help identify the diode below?
The plastic body of the diode below is ~0.175" x 0.103". The forward breakdown voltage is ~0.44v. The reverse breakdown was higher than the 210v limit of my power supply. They seem to be very leaky when checking on ohms instead of diode check.
Others on similar boards were marked:
X3 72
X3 6N
X3 62
Newer versions of the same board have diodes marked:
XH3 8401
Thanks in advance.
Old 7th October 2008, 01:34 PM   #2
Could it be any of components listed here: http://www.tkb-4u.com/code/smdcode/smdcodeX.php ?
Mark
Old 7th October 2008, 02:12 PM   #3
Geek's Avatar
I can't help, but I'd like to thank you for the very clear pic.
IMO, this is a nice example of how to ask for help
Old 7th October 2008, 06:23 PM   #4
I'm sorry. The Zener diodes that I was thinking of are SOT23 - it's not the one that you are looking for .
Mark
Old 8th October 2008, 02:05 AM   #5
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
It's definitely an SMA / DO-214AC package. Doesn't look like On Semi or Diodes Inc. labeling to me.
Brian
Old 8th October 2008, 03:14 AM   #6
Thanks for the responses.
With the package information, maybe I'll have a better chance of finding it.
Diode help dognut Parts 2 11th May 2009 10:41 AM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
What is this diode for? lumanauw Solid State 15 6th January 2007 05:14 PM
Is it a Diode? imix500 Parts 14 28th June 2004 12:17 PM
Page generated in 0.08175 seconds (71.26% PHP - 28.74% MySQL) with 11 queries
