Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st September 2008, 04:23 AM   #1
BERENO is offline BERENO  United States
BERENO's Avatar
Default Does this look right?
I have just laid out my plan for a XO for some speakers, and does this setup look right? More specifically I have two questions:
Are the inductors in the right position; namely the iron core?
Do resistors or caps have a polarity, and if so, how do I know which way to wire them?
here are some pics if you guys want to see them up close.
DISCLAIMER: Im a noob...
Old 21st September 2008, 04:39 AM   #2
ostripper's Avatar
Nope , Your resistors and caps have no polarity. Some would
disagree, but layout doesn't really matter.Just get the circuit
correct and check for shorts .
By the way , resistors might get hot
under severe "cranking"
so keep them separate from caps.
good luck..OS
Old 21st September 2008, 04:51 AM   #3
lineup is offline lineup  Sweden
lineup's Avatar
.... resistors may get hot
.... so keep them separate from caps
and when we use power resistors
we should mount them with a bit of air between resistor and surface below
this is to let the cooling airstream be able to freely pass
all the surface area, on all sides of the resistor
lineup
Old 21st September 2008, 06:57 PM   #4
BERENO's Avatar
Thanks guys for the advice good to know about the caps and resistors...
I know that air core inductors can interfere with each other when placed incorrectly (or so I am led to believe) but I am unsure of the solid core inductor.... anybody else know?
Old 21st September 2008, 07:39 PM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
You have the coils at right angles and far from each other. That's indeed the best you can do for minimal interference!
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 21st September 2008, 07:56 PM   #6
BERENO's Avatar
Ok, so solid core inductors DONT interfere with air core? If you can see in the pic, the solid core inductor is right next to the air core inductor near the top...
Old 21st September 2008, 08:02 PM   #7
janneman's Avatar
No, I missed that one! That's too close for comfort. At the minimum, turn it 90 degrees so that the filed of the big coil doesn't go through the little one.
Jan Didden
Old 21st September 2008, 08:04 PM   #8
BERENO's Avatar
OK, I was afraid that it would but I just wanted to make sure, thanks again to everybody
Page generated in 0.08531 seconds (72.89% PHP - 27.11% MySQL) with 9 queries
