| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi everybody...
I'm currently designing a schematic for an amplifier in EAGLE but I'm unable to find the screw terminals in the any of the libraries. I will be very pleased if someone could provide me with information of where to find the library or the library itself, combined with a matching part number at mouser/digikey/jameco etc. I have attached a picture of a terminal block below. It doesn’t have to be the exact type. Thanks in advance Andy |
#2 |
In Eagle you can find them, for example,
in a library called "con-wago-500". _ |
#3 |
Thanks for your answer.
I have found those too. But I want to be sure that the one I order fit the PCB. Lets say I choose the one named called W237-102. Do you know which partnumber these have at any international supplier of electronical components. Thanks in advance |
#4 |
Hello Zahrec, Those appear to be either from Phoenix Contact or Wago.
www.phoenixcontact.com www.wago.com The websites can be a little confusing at times to navigate, but once you figure it out they are very informative. I would suggest measuring the spacing on the contacts of the connector, that is one of the things they use to separate the connectors. There are multiple sizes of connector that look the same, but have different spacing between the contacts, and can handle different size wire and current ratings. If you can tell which manufacturer it is, contact them through the website for your country, they should be able to point you to a supplier who will work with you. Peace, Dave |
#5 |
Thanks for your useful answer.
| Screw Terminal Caps for Sale | Killjoy99 | Swap Meet | 15 | 27th January 2009 05:08 PM |
| FS: New Mallory 15,000µf 100V Screw-Terminal Capacitors | EchoWars | Swap Meet | 15 | 23rd March 2008 06:43 AM |
| Mounting screw terminal capacitors to chassis | ssmith | Pass Labs | 1 | 6th October 2007 04:25 PM |
| amplifier and screw down terminal connectors? | vtgolf | Chip Amps | 2 | 17th July 2007 04:40 PM |
| Page generated in 0.08075 seconds (74.97% PHP - 25.03% MySQL) with 11 queries |
