| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello everyone,
I had abandoned my hi-fi system about a year ago when I got too busy with work, school etc. A few weeks ago I began my diy efforts again and built the system back, this time as bi-amp. The sad thing was I didn't have much time and I could not build a diy crossover. I bought a Rane SAC 22 which came cheap and installed it as the crossover on my hi-fi system. Now I feel like a sinner putting a pro audio device with balanced connections in my link. I want to modify it with some better parts. Then perhaps I'll feel better The crossover works with TL072 opamps and selection of the crossover frequency is done by a voltage controlled amplifier SSM2164. I'm planning to change the electrolytic caps in the signal path and maybe the opamps with better ones. Rane offers the schematics of the board in its website which is pretty cool. I'd be glad to hear any comments on this subject. |
#2 |
Had a quick look at the circuit. I don't really think you will gain much trying to mod this. The TL072 is suprisingly good -- better than most folks give credit for. The current consumption of the TL0's is low -- something to bear in mind when there are a lot of them. Having said that OpAmps do have a subtle "character" but so much depends on how good the rest of your system is-and what your trying to improve. As to the caps, if they are reasonable quality "commercial grade" parts then again IMO I don't really think you will hear much difference. You might feel better |
#3 |
Hello Mooly,
I think you're right about changing parts from the crossover. Changing parts with similar ones do not offer much improvement. But there's lots of room for improvement in acoustics. I'll try to eq the Rane now My system has a dip at around 170Hz. I've found a peaking filter circuit from http://mysite.verizon.net/vze3xvxs/id1.html. I'm not sure what is the proper way to add it to the signal line but I think I will add it before the C46 and C52 coupling caps on the SAC 22. I may add a 1.5K resistor to the input of this filter circuit. I'll use an OPA2134. Here's the picture of my peaking filters. Not soldered but setup What do you think? |
#4 |
Couldn't find the circuit of the filter you mention but what you propose sounds OK. Trying to correct room response problems is never going to be easy. I think you will have to experiment a bit.
#5 |
Here's the link:
http://mysite.verizon.net/vze3xvxs/s...our_manual.pdf I've done my tests with foobar media player equalizer. Boosting 170Hz 6dB Q=0,9 and adding the treble unit about 1dB gain will very much improve the vocals and body of the sound. I expect to have good results - if it is OK to add this peaking filter to the SAC 22 on that location. I have the measurements of my speaker response measured from about 1m at http://keremdiy.blogspot.com . |
#6 |
I really think your going to have to experiment with this. This is an area I've never worked on -- trying to equalise room response problems. I can't see any problems with inserting the filter where you intend. The "peaking" filter looks as though it uses an OpAmp to simulate an inductor (Gyrator) to obtain the very steep transfer function. Not really my thing I'm afraid, I prefer the more direct signal approach. Good luck with it all |
#7 |
#8 |
Thanks kepa1 that helps.
This article will lead to some new work for me. First of all it's written for a AC 22 not a SAC 22. Secondly, the part codes on the schematics have changed on the AC 22 since then. I'll need to find the infrasonic filter and output caps on the SAC 22 and modify it accordingly. I'm also puzzled there's so much difference in the THD ratings of AC 22 and SAC 22. THD is 10 times higher in SAC 22 though it's a simpler model. I guess it's the opamps and the design of the output stages. |
| Rane AC22B Crossover | Kevin.kinchin | Parts | 6 | 14th November 2008 09:40 AM |
| RANE RPM 26z digital crossover | batdorf9 | Swap Meet | 3 | 18th April 2007 02:22 AM |
| For Sale: Rane AC-22 Active Crossover | herm | Swap Meet | 2 | 1st June 2006 04:54 AM |
| Two different version rane AC23 crossover | ostie01 | Solid State | 0 | 18th January 2006 12:20 AM |
| Rane MX22 Electronic Crossover 4 Sale | Bill Fitzpatrick | Swap Meet | 0 | 28th August 2002 01:42 AM |
| Page generated in 0.09257 seconds (79.61% PHP - 20.39% MySQL) with 10 queries |
