PSU capacitors: 30uF film ok instead of 100uF electrolytic? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th September 2008, 05:59 PM   #1
Default PSU capacitors: 30uF film ok instead of 100uF electrolytic?
I'm about to build the Hawthorne Audio 6CL6 Spud amp (2.5Wpc).
The schematic suggests that two 100uF electrolytic caps are used in a CLC arrangement for the B+ supply.
Would 30uF motor run caps be suitable replacements for the 100uF electrolytics?
The ESR of a typical 30uF motor run cap is lower than a 100uF 'lytic (at 100Hz) and the ripple current is much higher (more than double that of the 'lytic)....
Any advice would be appreciated :-)
Old 12th September 2008, 06:54 PM   #2
Did it Himself
richie00boy's Avatar
It will work but you will see drastically reduced filtering ability due to less series resistance and massively less capacitance.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 12th September 2008, 07:01 PM   #3
Banned
Yes, if the voltage rating is adequate and you use 4 in parallel for each 100u.
w
Oh, advice. Use the electrolytics.
Old 13th September 2008, 08:49 AM   #4
Tweeker is offline Tweeker  United States
High ESR makes a cap less effective, not more.
Either way the ripple performance (if not HF impedance) should still be overwhelmed by the difference in capacitance with modern elcos. A compromise would be to parallel the final cap with a film/oil cap.
Be sure your foil hat has a good low impedance ground.
Non-Polar Electrolytic vs. Polypropylene Film Capacitors gtforme00 Parts 30 1st August 2015 11:03 AM
100uF PIO capacitors BMW850 Parts 3 26th May 2007 04:25 PM
FS: United Chemicon KMG 100uF/250V electrolytic caps (50 pcs) Maxhawk Swap Meet 0 10th February 2006 10:26 PM
film vs. electrolytic metebalci Parts 9 6th August 2004 11:44 AM
FS Black Gate SKZ 350v 100uf/100uf x 2 capacitors Mark Hathaway Swap Meet 0 1st March 2004 08:25 AM
Copyright 1999-2017 diyAudio
