| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
For large solid state amplifiers, has anyone used individual heatsinks for their output transistors instead of one or two large plate heatsinks that all of the devices are mounted to?
I am having good luck finding cheap ~60mm X 60mm heatsinks on eBay that are intended for microprocessor CPU cooling ---> If I have 10 output devices in my amplifier (TO-3P plastic package), can I buy 10 of these heatsinks and mount all of my TO-3P output transistors to their own individual heatsink? Is there any problem that the transistors will not be "sharing" their heat with their neighbors? After doing the math, some of these heatsinks sell for $3 each --> 10 X $3 = $30, which is cheaper than the cost of the larger heatsinks that can hold 5 devices a piece, from what I have found. |
#2 |
This is exactly what I'm doing for a Pass Labs project.... using many honkin' fanned CPU heatsinks I found surplus for really cheap.
I'm now working on the manifold and silencer for the fans Cheers! |
#3 |
CPU heatsinks are designed for forced air cooling, the fins are thin and spaced to near together for convection cooling.
They are cheap and I use them for many things (PSU's, chipamps etc ) a fan is neaded for any real heat dissapation though, can be noisy |
#4 |
Well I think it depends on the AMP...Many Discrete amps have a Transistor that has to be attached to the same heatsink at the output transistors for thermal sencing.....
Cheers |
#5 |
There are some significant advantages to having a single large heatsink verses multiple small ones. Check out www.apexjr.com.
He has some large heatsinks at good prices.
none |
#6 |
You really do need one big heatsink. However, you can make one out of a bunch of smaller identical ones by gluing them together with epoxy. Coat the ends and use a bar clamp until it fully cures.
If you end up using a separate one for the + and - banks, you'll need separate thermal compensation for each unless the air flow is dead even between them. |
| Leach but larger | taj | Solid State | 18 | 8th May 2007 07:06 PM |
| Wanted: Used B&G ribbons, the larger ones | stokessd | Swap Meet | 1 | 25th November 2006 03:28 AM |
| Larger box for sealed OK? | mazeroth | Multi-Way | 3 | 8th April 2005 06:58 AM |
| PS Cap to V- larger than the Cap to V+ | GregGC | Chip Amps | 4 | 1st June 2004 01:50 PM |
| Page generated in 0.08686 seconds (79.62% PHP - 20.38% MySQL) with 10 queries |
