| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi All
I acquired a Yamaha A-700 curbside and it has a set of o/p's blown on one channel. O/p transistors are Toshiba 2sc3370 and 2sa1333 for which I haven't been able to find information on, or replacements for. I have Googled and checked Toshiba etc. with no luck. Any help would be appreciated. Thanks Hugh
Lots of Fun and Good sound too - Who could ask for more? |
#2 |
#3 |
Smokin !!!! Thanks
#4 |
Your transistors are 200V, 15A, 150W, 30MHz, 600pF.
The spacing between the mounting holes is 21 mm. The other Toshiba's parts with these parameters are 2SA1302/2SC3281, but in a different case (width - 20 mm). These you can place between the holes and attach to the h/s with the appropriate AL bar/profile l___l with 2 holes, across the transistor. Another choice will be to use Sanken's 2SA1295/2SC3264 in the same 2 holes case: 230V, 17A, 200W, 35MHz, 500pF. With Toshibas you may want to use the same (single) letter grades. Sanken grading system is different, but you also will be better off with the same grades on the SA/SC - the last letter on the case. |
| Replacement for CDM 12.1 | Sandor | Digital Source | 4 | 12th June 2010 08:01 PM |
| Old Amp Pot Replacement | DeadSpeaker | Solid State | 0 | 10th December 2008 09:39 PM |
| Replacement amp for A-Bus? | Greg911 | Class D | 0 | 16th November 2008 02:33 PM |
| Replacement for 5R4 | Ralph | Tubes / Valves | 8 | 16th December 2003 10:02 AM |
| Page generated in 0.07505 seconds (67.86% PHP - 32.14% MySQL) with 10 queries |
