| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Not audio, but 'electronics and everything else', here goes. I am designing a piece of audio equipment that involves a uController, an LCD and an analog level chip. The LCD needs 5V digital signals, the level chip can only work with 3.3V digital commands. The uC can run on either voltage. I had this plan: run the uC and LCD from 5V, the level chip from 3.3V. Then drive the level chip control lines from the 5V uC via a resistor. The voltage at the level chip would rise above 3.3V, the internal protection diodes would limit that voltage to 3.3V + 0.5V, and the series resistor limits the current into the protection diodes to < 1mA. Would that work? Or do I need to get some level translators? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#2 |
It sounds ok to me. I've done the same except I used external diodes, not relying on the internal ones. You could of course use zener(s) to be safer.
#3 | |
Hi Paul, Thanks. Did you have an issue with a logical zero from the uC not being able to pull down the input of the other device because of the series R (I intend to use 1.8k)? Jan Didden
| PS 1, SCPH-1001 & controller, for parts, $5 | pjanda1 | Swap Meet | 0 | 17th March 2009 09:14 PM |
| SELLING DIY Projector parts Pixelworks controllerˇˇfor 15.4wu lcd | carpow | Swap Meet | 1 | 24th May 2008 03:23 AM |
| Page generated in 0.06383 seconds (71.07% PHP - 28.93% MySQL) with 10 queries |
