| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
If I would post this stuff you would probably think I'm pulling your leg: a solid state resistor that can be adjusted by electrically changing the physical properties. Enter the Rejustor.
http://www.mbridgetech.com/pdfs/MB-A...-Primer-AN.pdf Jan Didden
/Another new issue: Linear Audio Volume 3! |
#2 |
A resistor, that changes value, when another signal is connected.
Isn't that a transistor ?? No I didn't read the pdf. |
#3 | |
No, because the new value stays when you take the 'set' voltage away. You should have read the pdf .Jan Didden
#4 |
Electrons are yellow and more is better!
Mr. Didden, this was a really new thing for me, very interesting for future projects.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
is it achieving the same effect as laser trimming but using software to trim?
It appears to be permanent, one cannot return back to the start value.
regards Andrew T. |
#7 |
App note not says different. The rejustor can be changed a dozen of times at least.
#8 | ||
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#9 |
1 mW per device ?
#10 |
Programmable resistor.
Hear the real thing! |
| Page generated in 0.08398 seconds (84.06% PHP - 15.94% MySQL) with 9 queries |
