Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st August 2008, 10:58 AM   #1
trodas is offline trodas  Czech Republic
trodas's Avatar
Send a message via ICQ to trodas Send a message via AIM to trodas Send a message via MSN to trodas
Question K3067 busted - recommended replacement?
( back photo - http://s232.photobucket.com/albums/e...067busted2.jpg )
So, recently I turned one of my folding machines - a "webserver" one, using Abit KD7-G mobo and powered by Enermax 431W PSU ( http://www.pcstats.com/articleview.cfm?articleID=409 ) and mid loud explosion happen. Machine did not power on anymore.
The PSU is recapped with quality caps, but I'm affraid that with the Panny TS-ED caps in the input, their ripple is maybe too high and ESR too low, so maybe that is what caused the mosfet pictures above to end how it end. After cleaning I find out that also the 2M ohm resistor to the base of this mosfet is damaged (part of it's leg to the mosfet is gone) and 10A 250V fuse is busted badly - almost like the wire exploded and wallpaper itself on the glass of the fuse
Nevermind. It looks as Fairchild component, very similar (likely) to this Toshiba mosfet: http://www.alldatasheet.com/datashee...A/2SD3067.html
Basicaly it is 600V mosfet, 2A current (1mS pulse 5A, 100uS pulse 8A) with RDS(ON) 4.5 ohm and plastic core. Can't find anything on http://www.fairchildsemi.com
So, anyone got idea about available higher grade (mainly lower RDS(ON) and higher current, at least 4A ... ) replacement, guys?
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
...just keep folding, just keep folding... my config
Old 21st August 2008, 05:57 PM   #2
trodas's Avatar
I managed to quickly find was a NTE2387 at Mouser, but they asked $13 for it, so... a bit crazy, and it was not TO-220FP - eg. not the isolated one and I cannot have like 250V on the heatsink, that is no-go
K3067 - 600W, 4.5 Ohm RDS(ON), 2A (TO-220FP)
STP3NK60ZFP - 600V, 3.5 Ohm RDS(ON), 2.4A (TO-220FP)
NTE2387 - 800V, 2.7 Ohm RDS(ON), 4A
STP4NK60ZFP - 600V, 2.0 Ohm RDS(ON), 4.0A (TO-220FP)
STP5NK60ZFP - 650V, 1.6 Ohm RDS(ON), 5.0A (TO-220FP)
The best choice is clearly the STP5NK60ZFP, but no stock in Digi or Mouser, but just a slightly worser STP4NK60ZFP is available: http://search.digikey.com/scripts/Dk...=497-5980-5-ND
So I think I will go with it.
I also have to investigate the cause of failure, because, well, you know. Mosfets did not failing out of the blue, but I was unable yet to find anything besides the gate resistor (2 Megaohms!) damaged (one of it's leg near the mosfet was missing, burned/blasted away) and the fuse blown. And the mosfet cracked.
I beginning to slightly suspect the mosfet failed. The resistor is up to date still 2M (okay, like 1.96 my DMM say) and nothing else is visibly damaged, so, we see when I obtain thru friend or somehow the mosfet.
I probably give it another inspection, just in case I missed something.
I suspect the mosfet failed on the Power On, because I replaced the input caps in the PSU with hi-grade Panny TS-ED caps and they have like twice the ripple the original crap caps had... so maybe there come the source of failure?
We see
busted vega. could use some help rx7speed Multi-Way 5 13th February 2008 07:27 PM
my amp is busted elmer Instruments and Amps 6 16th September 2007 08:33 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
busted JVC turntable. help? beffie Analogue Source 5 26th April 2005 03:22 AM
is it busted? themadhippy Tubes / Valves 2 3rd October 2003 09:03 PM
Page generated in 0.07538 seconds (73.10% PHP - 26.90% MySQL) with 10 queries
