| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm re-wrapping connections on a vintage Marantz receiver and notice the old wiring is silver coated copper. The pins are also tinned. So, do I need to use coated copper wire to do proper wire wrapping here or does any solid core copper wire good enough? 22 gage if that matters and I'm using a manual wrapping gun. I can't seem to find 22 gage wire that is silver coated...
#2 |
Not of much help, but I did a lot of wire wrapping for many years 25 years ago.
As I recall the standard wire wrap wires we used (standard product at that time) was silver over copper, and bought in different length and colors. It should be possible to still get it. I know Farnell.com has it in 26AWG but only in length of 100 meters (app. 330 feet)
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
the oxidation over silver and the oxidation over solder are both quite soft.
Wire wrapping should be suitable for both finishes, silver plated and tinned. The oxidation over copper can be very hard. I would not recommend plain copper for wirewrapping, just in case the copper oxide on the surface insulates the wire from the post at all those corners.
regards Andrew T. |
#4 |
I've only been able to find 24awg silver coated wire for wrapping and it ain't cheap:
http://www.newark.com/87F6009/cable-...ies-ksw24b0100 Would it make sense to use the plain copper wrapped and then finish off with solder? It feeds the output transistors in a 85watt amp. |
#5 |
I stock some 22 AWG silver plated solid core PTFE coated
wire in the following colors... White, Green, Orange, Grey and Violet. Priced at .13ft --- $12.00/100ft in one color Steve @ Apex Jr. |
#6 | |
Thanks Steve, I'll put an order together shortly.
| 22 AWG silver plated solid copper wire for speaker wire? | G | Full Range | 21 | 15th February 2009 09:32 PM |
| Wire Wrapping Tool On the Cheap | DreadPirate | Parts | 1 | 28th May 2008 11:14 PM |
| Selection of proper wire for Ferrite core | xyz9915 | Power Supplies | 4 | 31st March 2008 06:00 PM |
| magnet wire (not sure of the term) used as chassis wire? | jarthel | Parts | 8 | 27th September 2006 09:50 PM |
| How to wire a Ixos Gamma 7 bi-wire cable | mangalchacha | Multi-Way | 1 | 13th April 2005 02:58 PM |
| Page generated in 0.08960 seconds (78.87% PHP - 21.13% MySQL) with 10 queries |
