Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th August 2008, 07:40 AM   #1
Default Help Identifying Transformer SLT5M329
I'm wondering if anyone can help me identify the power transformer in an old amp I just acquired. The amp is a Techniques SU-Z55. The transformer is labelled SLT5M329. All I can find through google is that it's a Panasonic transformer. I'm guessing by the plate on the amp that it's a 260VA. The chip in the amp is a STK2038B, which lists a max voltage of 55V and a nominal of 36V. The main filter caps are 10,000uF 56V models, black Panasonic (CE?). If possible, I would like to salvage the transformer for a gainclone.
My best guess would be that the last two digits are the voltage, 29V, which would give around 41V DC rectified. Anyone know for sure?
Old 18th August 2008, 12:04 PM   #2
Upon looking at the amp some more, it seems the transformer has quad secondaries, two each at two different voltages. A switch on the back for selecting the speaker impedance selects which voltage is used by the amp.
Identifying output transformer leads bereanbill Tubes / Valves 7 24th April 2009 02:27 AM
Help identifying Output transformer georgepw Parts 2 4th March 2009 08:02 AM
Help identifying IC mtl777 Parts 4 17th May 2008 09:10 PM
Help identifying transformer? dclapp Parts 2 2nd May 2007 01:28 AM
Identifying weird signal transformer Klimon Tubes / Valves 4 28th August 2006 12:50 PM
Page generated in 0.06093 seconds (69.74% PHP - 30.26% MySQL) with 10 queries
