Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th August 2008, 06:40 PM   #1
Default a leaking cap
hi folks
any easy simple ways to tell if an electrolytic cap is leaking or bad?
thanks
Old 18th August 2008, 04:36 PM   #2
Mooly's Avatar
If we are talking electroylitics leakage is usually visible, corroded look, green/furry looking etc.
How to tell if it's bad, measuring it's value is not the way to do it, you have to measure it "goodness" which involves measuring the ESR or equivalent series resistance for starters.
Old 18th August 2008, 04:43 PM   #3
hi buddy
thanks for your reply
but how do i
measure its "goodness" which involves measuring the ESR or equivalent series resistance for starters?
regards
Old 18th August 2008, 04:58 PM   #4
Mooly's Avatar
I wondered if you would ask that. Again we are talking electroylitics. You can do it with a 'scope and signal generator or you can ( I think -- never bought one ) get ESR meters. I have homemade circuit, not of my own design, that actually goes one better than ESR and measures phase angle or TAN Theta, of the voltage across and the current through the cap and displays the result on a DVM. It's quite a complex bit of kit really. One of Cyril Batemans "inventions" from about 10 years ago.
It's interesting comparing different caps, but to be honest most modern components are pretty good these days, and if you suspect a cap is playing up it's cheap enough to renew them all and have done with it.
Have you a 'scope ?
Old 18th August 2008, 07:43 PM   #5
MRupp is offline MRupp  Germany
MRupp's Avatar
Just test the leakage current I'd suggest to apply the rated voltage through a resistance of ca 10 - 50 Kohms. After a some minutes, depending on the capacitance/voltage/resistance, it should reach it's rated voltage, except for the very small leakage current. You can calculate the expected leakage current of a cap from formulas given in the datasheets, and if you do not have the right datasheets, those leakage currents are usually in the same ballpark for different brands.
Martin Rupp
Possible leaking capacitors NAD 370 [photos] zaibatsu100 Solid State 1 20th July 2008 01:39 PM
Capacitor leaking? limvingen Solid State 6 7th March 2008 04:46 PM
Leaking Transistors latala Solid State 6 15th July 2006 03:10 PM
leaking current jb_val Solid State 15 15th December 2005 10:00 PM
Are my caps leaking or glued on? Zuma Parts 7 24th September 2003 01:43 AM
Page generated in 0.06408 seconds (81.79% PHP - 18.21% MySQL) with 10 queries
