| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I just have a quick question and was hoping to take advantage of some of your expertise. I am thinking about changing the capacitors on a pair of microphones, specifically Microtech Gefell sms2000 bodies. The current capacitors are Philips and are labeled 40V 47uM. I believe that would indicate 47UF with 20% tolerance is that correct? They are extremely small axial caps fwiw. I would like to change the caps for whatever is the accepted top of the line or any other suggestions you guys with more experience than I may have. Thanks in advance for the help and suggestions, I truly appreciate it.
Regards DVRL |
#2 |
Size could be a problem. I like Panasonic ECA series. Part number ECA1HAM470X is 47mfd 50 volt and they are small. To be honest I don't think you will gain much by swapping the Philips part. Philips caps are usually pretty good I find, certainly the ones I have come across in commercial equipment are when I have tested them for ESR etc.
Edit, Enter that part number in www.cpc.co.uk and then click on the order code for full spec. |
#3 |
Agree, just replace a cap is not going to bring your much diff.
| PSU Capacitor question | Cloth Ears | Chip Amps | 11 | 17th January 2010 12:56 PM |
| Capacitor Question... | SigloOne | Tubes / Valves | 15 | 3rd May 2009 07:39 PM |
| Capacitor question... Again and again... | Dxvideo | Chip Amps | 14 | 9th January 2008 09:27 AM |
| capacitor question | crippledchicken | Solid State | 3 | 31st October 2007 10:12 PM |
| Capacitor Question | audiodumb | Car Audio | 15 | 22nd June 2005 04:49 PM |
| Page generated in 0.06978 seconds (73.47% PHP - 26.53% MySQL) with 10 queries |
