| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi everyone!
I'm looking for suggestions on how to layout a front panel that will include a display. The display has 4 2.5mm diameter holes for mounting. I was considering taking a aluminum front panel and attaching a piece of colored plastic to it to act as a filter. In order to do this, I'd route out the back of the aluminum panel a bit and it would sit flush behind the panel. If your familar with Front Panel Express, the cutout would look something like this: ![]() The only issue that remains, is how to attach the display? Any recommendations? |
#2 |
Anything wrong with drilling holes in the front panel, and mounting the display with hex standoffs? Hex or Torx socket-head screws in stainless steel or chrome are usually attractive. I'm not sure that routing the back of the panel to countersink the filter is necessary. Just cut it about 1 cm oversize in each dimension, and apply a bead of RTV (silicone) around the perimeter and it should stick solidly.
The filter is a good idea; I've worked on equipment that used LCD displays without protection, and they tended to scuff or scratch quite easily. You might want to consider using glass, if it is available in a suitable color. It should stand up to cleaning better. If you want to get really fancy, have it engraved, or mask off the useful area and sandblast it. Then if you edge-lit it with some colored LEDs the frosted part should glow. Just an idea that crawled into my head... |
#3 |
You can do 4 blind threaded holes at the back of your panel to hold the display.
#4 |
You would need a thick faceplate then... Why not use a tall piece of angle stock attached to the bottom, with the other side sandwiching the LCD to the front, maybe add some hot glue.. and you could probably reach the bottom 2 screw holes... 2.5mm means it needs and m3 tap and screw...
#5 |
displays are usually mounted in one of two ways:
to a circuit board PEM hardware - captive hardware pressed into sheet metal. |
| Indicator LED mounting i thick front panels | NicMac | Parts | 6 | 11th August 2009 05:33 AM |
| How to print on front panels? | berthej | Everything Else | 9 | 12th October 2007 01:44 PM |
| Front Panels | jackinnj | Everything Else | 0 | 20th October 2004 07:23 PM |
| Professional looking front panels | jackinnj | Parts | 3 | 10th January 2004 04:39 PM |
| Custom Front Panels | haldor | Parts | 0 | 27th January 2003 09:06 PM |
| Page generated in 0.07735 seconds (72.39% PHP - 27.61% MySQL) with 11 queries |
