Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th August 2008, 03:48 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default Large Caps - Any good?
I managed to "rescue" these caps from an industrial machine.
They are very large but the capacitance & voltages don't seem that high compared to modern day sizes. (CD case in pic to give idea of size)
The first is an LCR 2500uF 350Volt - about the size of two stacked cans of beans and roughly the same diameter - I think this is a polyprop but I can't find anything on the interweb. Any good, do you reckon?
The rest are Mallory elec caps. They are 1100uF 450V & 150V and finally a Plessey 1.5uF 400V poly cap?
I'm thinking of trying the LCR on a PS but would be concerned about strain on the rectifiers at startup.
Whatdaya think? Worth keeping?
Old 12th August 2008, 03:49 PM   #2
Banned
Close-up shot
Old 12th August 2008, 04:12 PM   #3
analog_sa's Avatar
Default Re: Large Caps - Any good?
Of course it is not a polyprop, it is an electrolytic. These caps can take high ripple currents and that's one of the reasons they are so big. LCR is above average sounding cap ime. You can limit the current with a resistor and switch at startup. A choke input filter will also help.
Old 12th August 2008, 04:15 PM   #4
mwmkravchenko's Avatar
Default Good maybe !
Hi jkeny
The LCR cap was made in May 1990 around 18 years old. If the machine was running there is a possibility it is still good. But if it has been sitting for a while you will need to reform the cap.
Mark
Mark
Old 12th August 2008, 06:22 PM   #5
Banned
LCR cap says 36MA (this is not a lot of ripple - if that is what it means) on the cap sleeve & I don't see any + or - terminal symbols or colours on the pins or cap sleeve - this is why i thought it was a film type. How do I know which is pos terminal then?
Mark did you find info on-line on the LCR cap?
What about the Mallory caps - any use holding onto them?
Old 12th August 2008, 08:02 PM   #6
Banned
Sorry, you are right - I found the + symbol on the top of the LCR cap buried under some dust!
Large caps Stuart Easson Swap Meet 26 25th March 2009 03:57 AM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Where to buy large caps in Europe? Sony Pass Labs 7 8th May 2005 11:16 AM
Is it OK to add a large bank of caps outside the amp? mattjk Solid State 4 15th November 2004 03:18 PM
Page generated in 0.07455 seconds (80.70% PHP - 19.30% MySQL) with 11 queries
