Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th August 2008, 06:57 PM   #1
Default help choosing heatsinks for transistors
I'm ordering parts from mouser and digikey USA and need some help finding proper heatsinks for two transistor types
IRFI820GPBF-ND (digikey #) TO-220F
689-LND150N3-G (mouser #) TO-92
I can order from either site, and prefer copper if available...
Both parts are used in two places
dac output stage with about 30ma running through it
70V regulator board that feeds the dac stage
There's a zillion heatsinks on these sites, and I don't know where to begin. Any help is greatly appreciated!
Cheers ~ Mike
Old 27th August 2008, 10:13 PM   #2
dmills is offline dmills  United Kingdom
Calculating heat sinks is fairly straightforward:
Given worst case voltage across and current through the part, calculate the amount of dissipation (so a transistor running 30mA at 70V across the part (Not 70V total rail!), will dissipate 70 * 30 = 2100mW = 2.1W.
Next figure out the maximum junction temperature you can live with (say 120 degrees C if unsure), and the maximum ambient air temperature around the heatsink (I use 40 degrees C for an external heatsink, or 60 for an internal one, probably both well conservative), so lets say this heatsink is inside the box:
Tj(max) -Tamb = 120 - 60 = 60 degrees C, and power is 2.1W, so the maximum total thermal resistance from the junction to the air of 60/2.1 = 29C/W.
Subtract the thermal resistance of the package internals (from the datasheet), and the insulating washer (if required) and you get a maximum value for the thermal resistance of the heatsink.
Pick one with a thermal resistance lower then the value calculated (Half the value calculated if you can make it fit is good for reliability).
Regards, Dan.
Old 27th August 2008, 11:27 PM   #3
Very educational feedback. Thank you Dan!
Cheers ~ Mike
Loads of DIY Stuff for Sale! Amplifiers, transistors, IC's, heatsinks, XFMR's etc!!! opc Swap Meet 76 23rd August 2009 10:43 PM
Garage sale (transistors, heatsinks, misc parts) maurycy Swap Meet 2 27th February 2009 05:10 PM
Need help choosing USB DAC kit. imperfectcircle Digital Source 16 14th August 2006 02:13 PM
Heatsinks,Transformers,Transistors,Amplifiers PassFan Swap Meet 1 10th December 2001 02:51 AM
FS; heatsinks, toroids, transistors, boards,... km Swap Meet 7 12th September 2001 11:21 PM
Page generated in 0.07360 seconds (71.11% PHP - 28.89% MySQL) with 10 queries
