Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th August 2008, 02:53 AM   #1
Studio1 is offline Studio1  New Zealand
Default Flat drive belts
I've got an Otari CTM-10 which needs a new drive belt for the pinch roller engagement mechanism.
It's a flat belt - 5 mm wide across the flat. Even a mil or two bigger wouldn't be an issue.
It's 0.6 mm thick.
The belt, when laid flat on the table, is 50 mm long - end to end.
By flat on the table I mean with the 5 mm flat side against the table, then push the belt down at both ends so it is layered on itself.
Any suggestions? I've tried various belt suppliers in the USA but no one has one this small. If they do, it's not wide enough.
Need new drive belts for Aiwa ADF-770 tape deck mixter_v Analogue Source 15 23rd June 2010 12:02 AM
Replacement drive belts Nam402 Analogue Source 1 11th July 2006 10:17 AM
Aiwa F 660 & 770 Cassette deck Drive Belts bk.bas99 Analogue Source 6 6th May 2006 12:37 AM
TT drive belts. Paul Dimaline Analogue Source 3 17th October 2005 03:50 PM
Breaking in drive belts; pickup cartridges etc. Circlotron Everything Else 9 12th November 2003 08:00 AM
Page generated in 0.05586 seconds (80.68% PHP - 19.32% MySQL) with 10 queries
