Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th August 2008, 08:02 AM   #1
Default help identify anode of this diode rectifier
I am newbie on this, please help me identify the anode and cathode pin for cree diode rectifier CSD01060.
i attached the picture and mark the anode and cathode of the pin. please correct me if i am wrong. thanks in advance
Old 6th August 2008, 08:21 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Why not just measure it to be sure?
Put a 5VDC or the plus of a 9 V battery on one pin, from the other pin go through 220 ohms to the + of a LED, other lead of the LED back to the - of the supply or battery.
Swap the diode pins until the LED lights, then you have the + on the anode.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 6th August 2008, 08:29 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
Too tired to google for a datasheet, eh?
http://www.cree-microwave.com/produc...CSD01060.L.pdf
Pinout is also given.
Have fun, Hannes
Old 6th August 2008, 08:39 AM   #4
Have fun, Hannes
Hi Hannes
thats the problem, i did find the datasheet, but im totally newbie. which pin is anode and which pin is cathode? thanks alot
Old 6th August 2008, 08:55 AM   #5
milen007
What u have written on the picture is wrong. It is the other way round.
Be aware that the case is also connected to the cathode, so do not let it touch/mount it to a grounded metal, unintentionally.
Enjoy
Gajanan Phadte
Old 6th August 2008, 09:15 AM   #6
Hi gmphadte
thanks for the input. it matched the result from hannes.
thanks guys. i love this forum
Old 6th August 2008, 09:45 AM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
You could also identify the leads useing the diode test on your multimeter...
Old 6th August 2008, 01:52 PM   #8
Elvee is offline Elvee  Belgium
Which is probably the safest option, as diodes are generally available in normal or reversed versions.
Old 7th August 2008, 02:31 AM   #9
if the diode test does the bip sound. is it anode or cathode that connected to the positive/red lead of the DMM? thanks
Old 7th August 2008, 04:13 AM   #10
If u are using a digital multimeter, the red lead supplies positive (from the DMM battery). The diode will beep when the anode is supplied with +polarity.
Don't confuse yourself of the supply on the meter leads. It is needed to test Rs and other passive components including diodes. However, on a DMM, u have to set the range to diode test. The resistance mode will show open in both the directions.
The polarity of the traditional analog multimeter is reversed.
Gajanan Phadte
Need help identify the diode milen007 Parts 13 3rd January 2012 07:46 AM
Tube rectifier to diode bereanbill Tubes / Valves 19 19th May 2009 11:37 PM
BYV79E as rectifier diode tubee Solid State 5 18th June 2008 02:45 PM
diode rectifier ratings redrabbit Power Supplies 8 13th November 2006 05:33 AM
Rectifier diode for Non-os Dac tonitze Digital Source 0 24th August 2003 04:33 AM
Page generated in 0.10263 seconds (78.35% PHP - 21.65% MySQL) with 11 queries
