Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd August 2008, 09:59 AM   #1
Stuey is offline Stuey  Australia
Default Old style trim pots
I'm refurbishing a 70's Onkyo tuner in which there are a number of those large style trimpots, with a footprint of about 10 mm x 12 mm (pure guess on these dimensions).
What do people use now to replace these? Or are they still available?
Cheers
Stuey
Old 2nd August 2008, 11:35 AM   #2
I just re-read this and realised I'd been a bit vague. They are the horizontal type, open, with phenolic insulator and open metal wiper. The classic cheapo trimpot. But they're quite big.
I'm wondering if in repair, people are using a different type. I'm not sure of their power rating.
Cheers
Stuey
Old 3rd August 2008, 10:49 AM   #3
Mooly's Avatar
I know the one's you mean. Very common in 70's gear. Are they dickey (loose rivets etc) or were you just after changing them to be sure. Worth taking them out and soaking in WD40 and keep spinning them round a few times. Other than that you will have to search the catalogues I'm afraid.
It's nice to do a good job though
Old 3rd August 2008, 11:00 AM   #4
Hi Mooly,
Yeah, one's knackered. It's a 50K one and has a range of 1K to 2.5K or so (used as a variable resistor). I actually just realised today that they're even bigger than my estimates above.
I may just replace the broken one with a single turn cermet (sealed type).
Cheers
Stuey
Old 3rd August 2008, 11:41 AM   #5
Mooly's Avatar
If it's duff there's no option really, it's just nice to keep things original. Is there enough "print and space between print" underneath so you could redrill new holes for new pots.
Old 3rd August 2008, 11:54 AM   #6
Sorry, I'm not sure I know what you mean... ?
Cheers
Stu
Old 3rd August 2008, 01:32 PM   #7
Mooly's Avatar
Could you re-drill new holes in the PCB to take new smaller pots so they fit properly and still solder to the original pads.
Old 3rd August 2008, 01:40 PM   #8
dnsey is offline dnsey  United Kingdom
Not quite whatyou're lookong for, I know, but would these be any good?
second series punch75 (pre-HD) trim pots Clipped Car Audio 2 21st March 2010 12:44 AM
Trim pots No Regrets Power Supplies 1 24th February 2009 10:00 PM
Bourns Multiturn Trim Pots pinkmouse Swap Meet 11 9th October 2006 11:17 PM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
Page generated in 0.08811 seconds (77.46% PHP - 22.54% MySQL) with 11 queries
