| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Electrons are yellow and more is better!
Hi!
Can anyone help me getting datasheets of 2SA968, 2SC2230? Toshiba
/Per-Anders (my first name) or P-A as my friends call me |
#2 |
RS Components ( http://www.rswww.com ) has the datasheet for the 2SA968 and its complement, the 2SA2238. You will need to register before you can access the technical information section of the site.
#3 |
diyAudio Retiree
This is for UK users only and requires a UK postcode during registration. Those outside the UK cannot order from the site. If do happen to go through all that and get registered, enter the part number in the search engine click on technical info. You must open the PDF and save it. Change the filename or it will save it as with filename data. the data sheets are there for these parts in Japanese. I will Email them to you Peranders to save you that much work.
#4 |
I don't like websites where I have to be registrated
At Toshiba I get the message "Datasheet not found".
#6 |
Beat me to it, I had just downloaded them!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 | |
#8 | |
http://www.datadart.com/al/datasheets2.html Thanks to Sherlock on OSX
| 2sa968/2sc2238 | Filburt | Solid State | 47 | 26th May 2012 01:08 PM |
| SMPS Datasheets | microsim444 | Power Supplies | 0 | 17th January 2009 08:11 AM |
| Looking for datasheets | satelitis | Tubes / Valves | 1 | 18th May 2007 09:37 AM |
| Philips datasheets | borges | Digital Source | 12 | 26th March 2006 11:56 AM |
| Page generated in 0.08168 seconds (76.68% PHP - 23.32% MySQL) with 10 queries |
