Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th July 2008, 11:54 PM   #1
Default salvaged capacitors
I am looking for information on the safe use of salvaged capacitors. I know that electrolytics require extreme caution in reuse but what I am interested in is other types such as Polypropylene, ceramic etc. It seems like the ceramic disks and Polys should be fine if they test well but I have a lot of caps that I can not identify type nor determine whether there are issues in reusing them.
One type of specific interest looks like a small sausage of molded plastic with axial leads. They are rounded on the end and look like solid plastic. One is labled 0.1 and 600V.
Can someone suggest web resources.
mike - www.keepingsundayspecial.org
Old 30th July 2008, 06:02 AM   #2
Found this picture on Ebay. A lot of the caps are similar to these.
Old 30th July 2008, 07:21 AM   #3
Elvee is offline Elvee  Belgium
They could be paper or plastic foil caps. If they test OK, you can reuse them without problem. Be aware that they are general purpose, low grade types: you can use them for non-critical applications such as coupling or decoupling, but in filter applications, they would give poor performances.
LV
Old 30th July 2008, 11:03 AM   #4
pilli is offline pilli  France
Also look at this:
MKP caps: are these for real?
Where they suggest techniques for identifying plastic cap types, based on capacity change when heated (positive or negative drift) and on the smell when burnt (but this is a "nonreversible" test).
_
Old 31st July 2008, 01:55 AM   #5
Thank you folks! Very helpful information. By poor performance in filter applications do we mean instability of the capacitance or other negative factors?
I have a lot of caps that look like orange drops that could be used in solid state filtering applications. Unfortunately (but not surprising given that the came from solid state organs) the "orange drops" and the "brown drops" (look like the common Chinese poly caps) all seem to be low voltage versions. I was really surpresed to find the 600V caps in there. Not always easy to figure out the voltage rating.
Just gotta find more vacuum tube stuff to salvage.
Old 31st July 2008, 06:43 AM   #6
Temperature stability could be a problem in some cases, because, the tempco is rather large, positive and non-linear, but I was thinking more of the loss factor: dielectric absorption, etc.
Old 31st July 2008, 07:04 AM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
I think for the most part, you could improve on most of those parts with modern equivalents made from better materials for reasonably low cost.
Need help to understand a salvaged Transformer. mastero Chip Amps 11 16th October 2006 05:25 AM
Drivers salvaged for a build... JandG Multi-Way 0 4th July 2006 05:54 PM
Salvaged transfo Nemophyle Chip Amps 10 8th October 2004 11:18 AM
Is there anything that can be salvaged from a UPS? JCoffey Chip Amps 5 2nd June 2003 01:04 PM
Page generated in 0.19233 seconds (40.74% PHP - 59.26% MySQL) with 11 queries
