Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th July 2008, 03:33 PM   #1
akis is offline akis  United Kingdom
Default Windows software for schematics and PCB
Hi there
Is there any software that you know of I can use to draw schematics and PCB layouts? I do not mean commercial costing 1 million pounds of course
Old 27th July 2008, 03:59 PM   #2
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default PCB
Eagle has a limited version for free:
http://www.cadsoft.de/
Limitations
The following limitations apply to the EAGLE Light Edition in general:
* The useable board area is limited to 100 x 80 mm (4 x 3.2 inches).
* Only two signal layers can be used (Top and Bottom).
* The schematic editor can only create one sheet.
none
Old 27th July 2008, 04:00 PM   #3
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Did you search ?
Layout and Pcboard software... please friends, suggest me something really simple
Need easy to use schematic program thats up to date
Cheap or Free PCB Layout software?
Plus many many more
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 27th July 2008, 06:25 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Kicad
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 27th July 2008, 07:11 PM   #5
Minion is offline Minion  Canada
I seem to use Express PCB most often because it is really easy to use accept that it has a limited Parts library ,But makeing custom parts is easy....For home made boards I just take the PCB design and use a paint program to make a design I can etch myself....
Old 27th July 2008, 09:58 PM   #6
hello, and thanks, I will try your suggestions, sorry for now using the search facility more effectively.
Old 3rd August 2008, 11:17 AM   #7
Hello again, I have been practising with Eagle light and have some questions
It allows me to create a board out of a schematic but once the board is present there is no way to tell it "scrap the board, I have changed the schematic, start all over" - to do this I manually delete the board file on the disk, and then it re-creates the board, but I thought there would be an easier way?
Even though I have specified 0.1" size routes on the schematic, the board "auto" applies very thin routes. I ended up drawing the lines by hand (which probably is neater).
Is there a way to (a) "use" multiple libraries instead of "use" one at a time? And how can you remove a library from the list, once you have mistakenly used it?
And finally, once I have the PCB bottom side printed in 1x or 2x on my laser printer, how do I transfer it to a PCB? Is there an easy method other than drawing the lines by hand with a special pen and then etching the board at home?
Many thanks
Old 4th August 2008, 04:31 AM   #8
brutepuppy's Avatar
Send a message via Yahoo to brutepuppy
PCB Artist has just about everything you could want. And it's a freebe to download. You cannot go wrong.
Old 4th August 2008, 05:30 AM   #9
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
thanks for the tip.
looks interesting ...
mlloyd1
Old 4th August 2008, 08:47 PM   #10
mobyd is offline mobyd  New Zealand
mobyd's Avatar
Caution - ties you to one PCB supplier
M
SoundEasy (& other windows audio software) via VMWare Fusion? hifiZen Everything Else 12 28th November 2008 08:04 PM
Zelscope for $20 - Windows software scope! lineup Equipment & Tools 17 15th June 2007 12:40 AM
Software for drawing tube schematics? JojoD818 Tubes / Valves 9 1st February 2006 10:21 PM
Schematics and PCB design software for Linux Kari Everything Else 4 16th January 2005 04:10 PM
A Software To Draw Blueprints Using Windows 98 OMNIFEX Multi-Way 1 10th August 2004 04:12 AM
Page generated in 0.10037 seconds (78.65% PHP - 21.35% MySQL) with 10 queries
