diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Who make the best 10,000uf capacitors (http://www.diyaudio.com/forums/parts/126982-10-000uf-capacitors.html)
Melon Head 26th July 2008 08:54 AM
I need to buy twelve 10,000uF capacitors for 2 power supplies (ie one for each channel).
Who make the best 10,000uf caps?
Who make the best value 10,000 uf caps?
OzMikeH 26th July 2008 11:30 AM
You havent specified what voltage.
Use more smaller ones. cheaper and better if laid out correctly. Do the sums and you'll see what I mean.
And that much capacitance is completely ridiculous for anything capable of being plugged into a normal outlet.
I suggest you do some more research on power supply theory.
Edit: typos.
h_a 26th July 2008 05:26 PM
It's not unusual to see 60000uF per channel in ClassA amps, OzMikeH :)
Which are 'best' - what does that mean anyway? - I don't know, but Panasonic TS-HA I consider a good bang for the buck.
Have fun, Hannes
lineup 26th July 2008 06:26 PM
2 Attachment(s)
If you have noticed my Avatar picture.
These caps are from a Mark Levinson power supply.
Where John Curl have been designer of amplifiers.
A close up of this power supply ( See Attachment ) shows they are PHILIPS electrolyts.
Now there are other making very good electrolyts.
http://corporate.evoxrifa.com/
May I suggest a visit to RIFA website. Evox RIFA capacitors.
They have very high class big capacitors.
They are often WHITE.
Here is their
Electroytic Capacitors Application Guide in PDF
http://www.evoxrifa.com/electrolytic...c_appguide.pdf
Here is another interesting paper:
HIGH VOLTAGE ALUMINUM ELECTROLYTIC CAPACITORS:
WHERE IS THE LIMIT?
http://www.evoxrifa.com/technote_pdf...tage_limit.pdf
Lineup
KBK 26th July 2008 07:13 PM
Nichicon KG's are very good. Likely among the best.
The others to try are the slit foil, 'DNM's T-Network', capacitors from BHC, of course, but specifically the DNM brand 'sourced' type.
Melon Head 27th July 2008 12:03 AM
I would like them at least rated to 35V
weissi 27th July 2008 12:08 AM
Epcos Sikorel
Melon Head 30th July 2008 11:48 AM
Epcos Sikorel look good
smithy666 30th July 2008 12:33 PM
Elna Cerafine were great, but no longer made (I sold a whole bunch of 10000uF/100V about a year ago)
For higher voltage 80V/100V and higher capacitance, I have been using Mundorf. Expensive but very good
Nordic 31st July 2008 07:06 AM
Sikorel, have a thick wallet handy... they are on average at least 4 times the price of other caps with similar voltage//capacitance...
Resources saved on this page: MySQL 18.75%
