| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 | |
Having said that, if I look at the datasheets that I have at hand and compare diodes of the same rating (ok, my shottky’s are dual devices) the shottkys have invariably a much lower forward voltage drop than the standard diodes. Example Ixys DSEP 15-03A (15 A, 300 V) VF _ IF = 15 A: TVJ = 150°C 1.21V, TVJ = 25°C 1.68 V IR 16CTQ100 (16Amp, 100V) VFM Max. Forward Voltage Drop 0.72 V @ 8A (Per Leg) at TJ = 25 °C 0.58 V @ 8A (0.69 V @ 16A) TJ = 125 °C The datasheets have diagrams with the related curves, and it becomes even more apparent. Same with other packages / higher current ratings, e.g. IR 40CPQ100 against various 30A diodes.
Martin Rupp |
#12 |
Thanks for the reference to the IR-schottky!
I'm not a diode guru, I have to admit that I randomly picked a cheap Schottky diode with comparable ratings from the Digikey-catalogue and it didn't perform that well. So the IR 16CTQ100 is 0.72 V at 25°C at 8 A (you state 0.58 V). For identical conditions the V30100S is about 0.52 V. Ok that's not that much. The really nice thing is the price! Your IR 16CTQ100 costs at Digikey 1.93 Euro in the uninsulated TO-220 package, the VF30100S goes for 1.17 Euro in the insulated TO-220 package. It's not exactly half the price, but good value for the money for sure. There are even standard Silcon-bridges that cost more than 4 of these. Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#13 | ||
On prices, Ebay is your frind; I found all my diodes (IXYS FREDs, IR Shottky's) at Ebay well below EUR 1 per piece, often still in the original tubes, and even the same types that boutique component suppliers (Thel in Germany) sell for an arm and a leg. Lastly, I suggest to use PSUDII to model your power supply to get the max current peaks, and if low forward voltage drop is your primary goal, run them hot (but not too hot).
Martin Rupp |
#14 |
Schottkys are the best when you are after low drop.
No question about this ![]() The only hookup with schottkys is that they often come for a bit lower voltages. But if your power supplies are not too high voltage, then it is a good option to get lowest power losses. I do not know the current developement in power Schottky. But I wouldn't be surprised if there are now higher voltage devices, too. Now there is, of course, an easy way to compensate: One extra winding in your transformer secondary ..... Best Regards to Dannemark, Dannebrogen och Hannes You are quite alright by me, man! The old school very, very Gentle Man of Svea Rike = Sve-rige = Sweden Lineup
lineup |
#15 | ||
@liney: thanks!! I'm not danske, but nevermind. And of course all the best to you, Hannes
#16 | |
Martin Rupp |
#17 |
Martin, don't worry, I perfectly understood! It's obvious from the datasheet. I was just joking
Have fun, Hannes
#18 |
/Another new issue: Linear Audio Volume 3! |
#19 |
Hi Jan, thanks for the article!
Amazing what things exist! Might be interesting for low-power gear! Just a pity that most discrete line-level gear exceeds its 26.5 V voltage rating. Do not fear smd, Hannes
#20 | |
Imagine, a 5A diode with 25mV loss only! Jan Didden
| MBR4060PT dual schottky rectifier as bridge rect. | jscherer | Parts | 4 | 25th February 2009 04:21 AM |
| LED forward voltage plot | ashok | Solid State | 7 | 26th October 2007 01:49 AM |
| Schottky rectifier cricuits | dqswim | Pass Labs | 4 | 9th January 2004 09:00 PM |
| Schottky bridge rectifier | TheTrax | Tubes / Valves | 5 | 3rd January 2004 10:28 PM |
| International Rectifier Schottky diodes | KevinLee | Swap Meet | 17 | 30th June 2003 09:37 PM |
| Page generated in 0.09935 seconds (87.61% PHP - 12.39% MySQL) with 10 queries |
