| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Wondered if anyone could put an age to this. It's the first piece of test gear I bought ( 30 years ago ) and it was second hand then. It covers 20Hz to 200+ Khz sine and square. It is a classic Wein bridge osc tuned by a beautifully made variable cap. The PSU is (was ? I could never part with it -- just given it a good clean with foam cleaner (all the internals) and dried it out --- perfect. |
#2 |
The PCB itself-- a lot of prescision resistors on there.
#3 |
The PSU. That would never be allowed today. Scary stuff, on an unearthed chassis. Even the paxolin switch has mains and LT on it
#4 |
Last one, that wonderful dual ganged variable cap. They don't make em like this anymore.
#6 | |
It's a brilliant little piece of kit -- it's biggest failing is that the large metal dial picks up 50/60 Hz and modulates the waveform at low frequencies. |
| HELP! Need Amp Info | nola000 | Solid State | 5 | 20th September 2010 03:29 AM |
| Need info on my Onkyo, can't find any info anywhere. | gixxierific | Digital Source | 0 | 19th April 2009 03:49 PM |
| How to get cathode bias info from grid bias info? | leadbelly | Tubes / Valves | 8 | 14th August 2008 04:40 PM |
| Info on this sub? | Howard | Multi-Way | 18 | 21st July 2003 09:38 PM |
| info on some IC'S | raindog | Parts | 2 | 17th June 2003 07:49 AM |
| Page generated in 0.07370 seconds (75.11% PHP - 24.89% MySQL) with 11 queries |
