| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm installing these output transistors to a heat sink. I've cleaned the mica insulators. Should I put HS compound (I'm using the white silicon type from RS) on BOTH sides of the insulator? The reason I'm asking is that there is clearly liberal amount on the original install between the mica and heat sink, but its not apparent that any was installed between the TO220 and the mica. Its a Marantz 2285B.
#2 |
Always clean off every bit of old compound. It dries out and won't work well on the second installation. Apply new well mixed compound to both side of the clean mica and install.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
.... Also, it should be applied sparingly, not liberally.
Frank |
#4 |
the compound is only there to exclude the air that would be trapped in the valleys between the high spots in the mating surfaces.
The high spots should be touching each other. If the surface finish is very rough then the quantity of compound between the non-mating surfaces will introduce significant thermal resistance. The better the surface finish and the less compound the lower the thermal resistance of the interface. But, you must strive to exclude ALL the air from the interface. This is far more important than any other consideration.
regards Andrew T. |
#5 |
Ok, since we are in TO220, I like to ask another question with regard to installation of the device. Hopefully someone can give me advise on it. My TO220s are installed on a large heat sink.And the heat sink itself is part of chassis common ground. I see the TO220 is screwed on to the heat sink and a insulator isolated the TO220 from the heat sink. Am I correct to say then the body of the transistor should be isolated from the chassis and the mica also serve as insulator? |
#6 |
Yes, that's correct.
Instead of mica, other isolation pads are also in use. I like silicon best, it doesn't break. Don't forget the isolation ring in the hole of the TO-220. Also make sure that everything is lined up nicely before fastening the TO-220 to the heatsink. Too often have I seen damaged isolation rings (and thus a short between TO-220 and heatsink) when this was not adhered to. |
#7 |
So I should not have read any resistance between the metal flange and the heat sink?
#8 |
you should read near infinite resistance from transistor to heatsink.
If you read near zero resistance you have a short.
regards Andrew T. |
| Is it OK to insulate a heat sink? | mtl777 | Parts | 15 | 6th April 2008 10:39 AM |
| heat sink for UCD700? | pburke | Class D | 68 | 7th July 2006 04:40 AM |
| LM3875 heat sink help. | CJ Paul | Chip Amps | 4 | 10th March 2006 08:14 PM |
| How much heat sink is necessary? | rosss | Pass Labs | 11 | 23rd February 2003 05:23 AM |
| New heat sink group buy | Brian Donaldson | Pass Labs | 5 | 25th January 2003 10:13 AM |
| Page generated in 0.08645 seconds (75.55% PHP - 24.45% MySQL) with 10 queries |
