Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th July 2008, 08:18 PM   #1
Default making a 61-0-61 9 ampere transformer help needed
hi guys iam a newbie
iam making a transformer with 61-0-61 9 ampere secondary .primary230 vac
with the help of software named transformer calculation by silvio klaic
i have a 4 number ei core with area of 360 square cm. the software says
with 235 volt ac
primary current-5431.914 miliampere
primary turns- 320 turns of 1.62mm wire (swg=16)
secondary turns -2x83 turns of 2.1mm wire (swg between 13,14)
the max power of core is 1296 watts
and my load is of 1262 watt so tell me is it ok with the calulculation or do i need some correction and also suggest the gauge of wire for secondary because theres no no exact swg equivalent for 2.1mm
thanks in advance
Help needed making an RCA Y cable ringo_the_hifi Analog Line Level 2 25th August 2009 06:26 AM
want to make 50-0-50 5 ampere mains transformer ravslanka Parts 9 3rd June 2008 11:25 PM
Help needed in making cinema speakers!!! noob! lions_gym Multi-Way 18 23rd May 2007 07:57 AM
FS: All parts needed for making DIY lcd $275 shipped!!!! echow87 Swap Meet 3 25th June 2004 08:38 PM
Page generated in 0.12866 seconds (45.54% PHP - 54.46% MySQL) with 10 queries
